Might anyone have an extra, original brake line
bracket which terminates the front-to-rear brake line:
it's located outboard of the driver muffler body mount.
Am changing a transverse single mufflered A-code '66
fb to a dual muffler setup.
NPD actually sells a nice repro.
I did the same thing on my daughter's 66 restomod coupe ('91 GT EFI & AOD - with duals).
I used the NPD bracket and it fit perfect - remove the rear seat - locate the stamped locating ridges in the floor pan - drill 2 small holes in the floor pan - have someone hold the bracket against the pan from the underside (USE GLOVES!)and plug weld it in place from the inside - looks almost factory! You could even bolt it in place if you want.
Thank you for the quick come-back. NPD it is.
Past experience with Viginia Mustang led me to them
and I will be even more carefull in the buying of
repro parts from now on. I could have made the
pre-bent piece of strap iron they sent me: it even
had a round hole which would have made it more
dificult to tighten the connection at that point.
They did credit me for the price when I voiced my
displeasure in a phone call. Oh well, live and learn.
Again, thanks!
In response to 64.5 07K, please note that we have never handled this bracket. You could not have purchased this particular part from us.
-Brant
Owner, Virginia Classic Mustang, Inc.
My bad, Brant!
I just found the billing from Mustangs Unltd. with
the rear brake line bracket included. Your order,
including the 66 AM/FM radio--what a beaut!!!!,
came in about the same time... ![]()
Your standing as an excellent vendor is hereby
reinstated, shouldn't have been impugned.![]()
Ned![]()
Tucson, Az.
I ordered the NPD bracket about a month ago. Looks good, but haven't installed it yet.
Thanks, Ned! I appreciate the message. I really like those AM-FM radios also.
-Brant
OOPS!...
NPD owned up to have nothing even close to
concours, just a bent piece of strap iron with a
round hole instead of an octagon hole for the brake
line fitting.
The search is still on....
Sounds like YET another part is being produced to "cheap" or China quality standards.
Keep looking around I'm sure you can find a bracket with the correct "D" hole. I do have to say that beyond the "D" hole for the brake line it is just a bent piece of metal with an angle cut on one corner.
I'm in total agreement, and Ford is getting their cut
from quite a few none-to-concours parts. It MIGHT
show what Ford is really after....a money grab, not
so much interest in keeping the old Mustangs on the
road.
With this in mind, I think we should be showing
our wholehearted support to those good vendors who
supply us and who are struggling to keep the name
"Mustang" in their company title.
