Really need C5ZZ-6028 and C5ZZ 6029 hipo mount pieces,as you may know these are L & R metal pieces that go between and attach to the frame mount bracket and motor bracket.Will pay your fair price.
Thanks Mike ![]()
Thanks Mike ![]()
Did find a set..just about had to get a loan from the bank,(just kidding.) Thanks to all for looking. Mike![]()
I've got those pieces, but been looking for the upper mounts that bolt to the motor along with the rubber blocks (these can be repro). I've yet to find anyone to offer some up...I'll also pay fair value.
Wayne
I probably have what you are looking for. I have the upper stufff with no lower parts. Just email me.
Bryan
BMaloof,
Sent you a PM...
I never got the PM
Are those part numbers the bottom part of motor mount that has the two pieces welded together and stud on bottom bolts to tower bracket?
Quote from RPMAre those part numbers the bottom part of motor mount that has the two pieces welded together and stud on bottom bolts to tower bracket?
QuoteThat's the ones,long bolt thru the rubber to motor mount,bottom stud to the C4ZA frame mount. Mike
I have the large rubber insulators in NOS if interested.
Brock
There is a letter missing on each number at the end as that is a universal motor mount part number?
The numbers that Hilo 38 posted are incomplete as RPM pointed out. The numbers are actually C5ZZ 6028 A and C5ZZ 6029 A. However these part numbers can not really be mistaken for any others as there was never any other suffix used with these numbers for any other application. These parts have no engineering numbers on them and are somewhat crudely made pieces.
