Hi Fellas
Where is the best place to look for Konis for my '65. I have a shipping address in Apopka Florida to get them home
Thanks Mark
Hi Fellas
Thanks Mark
If you just want a new set and not concerned about them being period correct, Summitt Racing sells them. They are expensive, but will be the last set of shocks you have to buy!
Mark,
If you need current Konis without date code correctness you must be able to find them in the UK. If not you can buy them from Holland or Sweden and get EU lower taxes on them. The part numbers are 1388 front and 1389 rear. The original 65 Konis in 1965 and used on the 65 Shelby were 1326 front and 1327 rear. Konis are made in Holland as you probably know.
Thanks guys
I looked on the UK site but had no luck, I will email them with the part numbers
Mark
Not sure of the cost with import duties, but http://www.tirerack.com has them on sale for $109 each.
Mark , can you let us know how you get on , it looks like the New Koni today is a different look , would i be right in this.
Shane
the photo of a koni in the ad mentioned above is not representative of of the ones for sale
Quote from k code 65Mark , can you let us know how you get on , it looks like the New Koni today is a different look , would i be right in this.
Shane
I am torn between getting some Gabriels that look like Autolites and are cheap or going for what I really want Konis.
If I get the Konis I will put up some pics before I fit them
Thanks Mark
Mark,
I have 4 used Konis I bought for my 65 Shelby many years ago.
As you know, I haven't driven the car that much but the
two front upper bracket bushings dried in the Texas heat
and should be replaced. Date codes are: Front 909 and Rear 911.
Removed them when I found 4 65 dated shocks for my car.
Also have 2 fronts dated 4 73 and rear dated 4 70. None of them leak but I have never used them. Both these pairs are 1388 and 1389's.
$100 each shock plus shipping.
Hi Bo
Will send you a PM to discuss
Cheers Mark
Piggybacking on this topic:
I'm searching for a rear pair of vintage Koni 1327's. Anybody out there have a set they're willing to part with?
Geoff
