• I know the history of the car from 1972 so im sure there 1960's,
    they are in good condition no cracks etc. The motor has the original 4100 carb,
    manifold and exhaust manifolds and cam so i wonder why someone put C6FE heads on? i mean their not to their full potential.
    Thanks Dan
    John
    Thanks Dan
    John
    Maybe they were cheap and seemed like a neat idea. I know somebody that bought an excellent used ex-factory race team set for $100 delivered circa 1980.
    Without full competition modification to go with them the C6FE heads might even be a step backward depending on the combustion chamber sizes. The chambers are larger than the chambers in stock heads as cast and can get larger during any reshaping and polishing work without milling the decks to reduce volumes. SA often used steel shim head gaskets or o-ringed decks with C6FE heads. The limit to them is still getting exhaust out.
    Dan
