4100 autolite for a 347 stroker
  • Interestingly 66 Thunderbirds with a 428 had 1.08 carburetors. I have a larger 4100 carburetor at home from the late 50's that is a 1.19.
  • i know that 112 4100 carbs were install on 390 engines , i thinking a 112 4100 would run well on a 347 stroker , just looking for opinions ,thanks.
    Depends on a lot of factors.
    First understand that the assembly line Ford 4100As in the 1.12 size normally test as flowing around 526± a little SAE corrected standard cubic feet per minute (cfm). That is without an air cleaner, which is a restriction. 4100As can be reworked to increase air flow at standard rating conditions for 4V carburetors. The highest average corrected flows I use to see usually for modified units came in around 570± cfm corrected.
    Second understand that most dynamometer horse power does not automatically mean quickest car. Every car maker and aftermarket company and a few magazine companies proved many times it is best to have a carburetor a little too small than any amount too large. Many sources publish good rules for 4V carburetor sizing for specific applications where only one carburetor is used. The rules change completely for individual running induction systems as the physics / flow dynamics are very much different. Box ram type manifolds change the rules.
    289 c.i.d. engines that are seriously race prepared using a single 4V carburetor calculate out to working best with carburetor flows between 403 cfm and 569 cfm depending on the engine revolutions per minute (rpm) at maximum power, volumetric efficiency, and what that rpm at peak power is. Believe it or not some of the most successful 1960s-1970s racers using 289 c.i.d. engines in Falcons and Mustangs dropped from the 1.12 size carburetors to the 1.08 size carburetors.
    How about a 347 c.i.d. engine? The carburetor type and size I would recommend depends on lots of factors: type of vehicle, vehicle weight, transmission specifics, differential gearing, open or limited slip differential, camshaft characteristics (what was it designed to do?), specific intake manifold and any modifications thereof, exhaust system, type of fuel to be used most of the time, altitude the vehicle was going to be used around most of the time, and the type of driving use most of the time and occasionally.
    At or near sea level, assuming a Ford 4100 something (1.08, 1.12, or 1.19 size) based on the original post, one might choose a carburetor with an actual corrected flow between 483 and 683 c.f.m. covering street driving that won’t land one in jail to serious high engine rpm power band racing. As one goes up in altitude the size of the carburetor used would go down to stay optimum. Just because most Ford stock calibrations were rated for 0 to 5,000 feet above sea level doesn’t mean the air fuel curves stayed the same as altitude increased.
    Also don’t assume your vacuum secondaries are doing much if anything. Several problems can render them inactive. Your 500 cfm 4V might work as let us say a 300 cfm 2V. (I just repaired an early 1966 MUSTANG GT350 R-3259-1 Holley® carburetor that has not been a 4V unit in many years. Years ago somebody installed some incorrect parts (2) during an overhaul and the secondaries were dead from then on. I test carburetors before I dismantle them and most Ford 4100A secondaries do not function at all in as received condition.) It is very good practice to test secondary operation before saying you are done with a carburetor. You must set up a scenario where you can visually verify that the secondaries open at an appropriate time and an appropriate amount. Vacuum secondaries are self sizing in that for a given carburetor the secondaries that won’t ever open on lets says a 221 c.i.d. engine might start opening at 2,000 rpm on a 430 c.i.d. engine.
    Dan
  • PS It is possible to take a "780" vacuum secondary carburetor and tune it (parts changes required) to work well on a 260 c.i.d. Ford industrial Engine in a Sunbeam Tiger or at the other end of the scale a 427 Light Weight or 427 HR race only engine in a 427 Cobra racer. There was a particular Ford carburetor that "size" that was specified and internationally registered as a racing option for Sunbeam Tigers, 1965 MUSTANG GT350s, and 427 Cobra full competition cars.
    Dan
  • ^ What Dan said ^ especially the part about bigger is not always better.
    I’ve always found it best to do some 1/4 mile runs with various carbs or if you have access to a dyno, that works too. This makes it obvious which carb is working best for your setup.
  • I have read for many years that using a 1.12 size 4100-A Ford carburetor on a small displacement V8 was not satisfactory for most who tried. The usual commentary wonders why factory HP289 engines did so well with such a large carburetor. It is only recently that a few of us have started documenting what we find in vacuum secondary control systems, yes control, in various assemblies. Failing to find any significantly detailed Ford engineering information, even in Bob Mannel’s library, we are recording what we find. No surprise really but many carburetors that have ever been apart before are not just as they would have been manufactured anymore.
    Stepping back a little, I have known since the 1970s that Holley® carburetors with vacuum secondaries used a control scheme to tailor secondary how much air flow through the primaries was required to trigger cracking the secondary throttle open, control how fast the secondaries opened, and control how much the secondaries would open in a given application. For a given engine size, Holley could have one “size” carburetor assembly crack open secondaries around 1,400 rpm and be fully open at 5,000 rpm and do another the same “size” that would not start cracking until around 2,400 rpm and never get fully open. That is the “shelf sizing” of vacuum secondaries you will read about, not really by itself until built that way. What Holley meant was something like an out of the box R-1850-1 will open differently between something like a 260 engine and a 430 engine.
    As it turns out Ford 4100 and 4100-A models were created with the same types of devices to control how the secondary throttles worked. Holley published their parts and methods while Ford just skimmed past them in training manuals and the Master Parts Catalogs. Holley published how what parts do what while Ford hinted in obscure publications most vehicle owners would never seen. As it turns out Ford carburetors are adjustable too. A 1.12 size unit factory calibrated for engine X might flop the secondaries open super early on a 289 engine, while one calibrated for engine Y might never start opening the secondary. A sudden snap open at mid rpm and low road speed would make horrible driving manners for a 289 engine. Never opening negates having a 4V unit.
    Our calibrated parts study is young. We are gathering up shared information, what Mr. Mannel had, and what I have found in Ford dealer and service information Ford used these features alone or in combination to control when, how fast, and how far secondaries operated. In the vacuum system circuit:
    One, or two in later years for some large engine models, vacuum pick up source tubes. Models with a tube rely only on air flow through the primary side to create a vacuum signal to open the secondary. Models with two tubes delay secondary start up and once the secondary starts flowing both tubes supply signal to finish opening the secondaries at a faster rate near the end of travel. (Holley did the same thing in 1965-67 MUSTANG GT350 carburetors. R-3259, R-3259A, and R-3259AAS assemblies 1964-1965 had a single vacuum pick up while R-3259-1A and R-3259-1AAS models 1965-67 used two pick up points split between primary and secondary.)
    Size of a calibrated orifice machined into the passage or size of the calibrated brass orifice pressed into the passage.
    Include a 1/8” check ball or not.
    Include a bronze coil compression spring with the check ball or not.
    Depending on calibrated orifice diameter and use with or without a check ball the secondary opening characteristics will be vastly different. You would not want the secondaries of a 1.12 size carburetor to open quickly and or all the way on a small V8 unless hard acceleration is what you wanted to do.
    I recently prepared a 1.12 size C4OF-AL HP289 carburetor for our black car. It was missing the check ball. I have a method of bench testing vacuum secondary carburetors before installation. For a 289/302 application I want the secondaries to open smoothly at a constant smooth rate in about three seconds of testing. Without the check ball the secondaries snapped open instantly. With a new ball installed opening was just under three seconds. That should be fine as the Holley model I took off had been tuned to open in right at three seconds. (The R-3259-1AAS was installed for a prior owner by his local Shelby dealer in the 1960s. The dealer ordered and installed a COBRA 4V induction kit. In the 1980s I tuned it to give world class performance under a wide range of conditions and fuels, street and track, around 600 to 700 feet above sea level. That development program is where I came up with my three seconds number from. I have tuned quite a few R-3259 family carburetors for GT350s and Cobras over the years and that three seconds number has been good for them all. I have done a few Ford C3OF-AJs for HP289s also. I will be testing the C4OF-AL this summer as the Holley seems a tad sluggish at low rpm were we live now at 5,400 feet above sea level. The smaller bores Ford carburetor should have more air flow speed through it at any given rpm and provide a little crisper tip in around town. We will find out. I have the Holley overhauled and ready to reinstall at some point in time.)
    We are using a Shelby American 1964 race shop 4-2V induction system in our red car. Moving from 600-700 feet above sea level to 5,400 feet above sea level required resizing the carburetors, which is easy with 48 IDAs. As we moved there was not enough air mass to ever get the main systems started under 5,000 plus engine rpm. We had to change air bleeds and fuel jets also but with smaller chokes the main systems work properly at 20 something mph in fourth gear.
    In choosing a carburetor "size" keep in mind how altitude affects naturally aspirated (carburetor(s) based induction systems) engines.
    Dan
    Dan
    Edited 3 times, last by Dan Case: add detail (March 10, 2021 at 6:27 PM).
  • Right on Dan Case!
    4100 flow rates posted are pretty close to what we saw at JBA back in the day.
    OP needs this monster 1.23 prototype for his 347 ;)
  • Still depends on location (altitude mostly) and of course vehicle specifics and driving styles.
    We live at 5,400ish feet above sea level now. In addition to lower oxygen content the relative humidity is often very low (8 to 23% has been common this summer). A day's outing might cover altitudes between 3,500 feet and 8,700 feet above sea level. Our black car got a dealer installed COBRA 4V induction kit and linkage kit for a Cobra circa early 1968. I retuned it for this area when we moved here and it was very nice but not as crisp in throttle response and felt light on torque in the mid range here as compared to in Alabama. I cleaned up a C4OF-AL and prepared it for a Cobra at this altitude and got back to crisp drive away and instantly responsive low to mid range tip in again. The R-3259-1 Holley® was okay but even more "too large" at this altitude. Yes, I am sure ultimate power is down with a smaller carburetor but I don't drive around zipping up to 6,000 to 8,000 rpm any more. Now it is more important to me for the engine to be super smooth under a wide range of conditions and immediately responsive. (The Holley installed decades ago is being kept and may go back on if I get to where I cannot drive the car much anymore. I have already serviced it for a return to duty.)
    Dan
    What is a 1.23 prototype , first i have seen one.
  • Apparently an escapee from Ford development. My information table indicated they had two sized of throttle bores 1.23 and 1.19. Some speculate it was an attempt at the "spread bore" concept. I have never found any data on SAE corrected air flow. One was for sale on eBay(R) not all that long ago. It was not a production model. There was a 1.19 production model in the 1950s that was very rare then and super rare now. Some big block engine folks hunt for the 1.19 size models.
    Dan
  • I got it off eBay. Listed as coming from the estate of an Autolite engineer. It's supposedly a carb intended for paxton applications.
  • I removed a Holley from mine and bought a 1.12 hipo carb from Pony Carb somewhere around 2000. Works great, worked even better when I had 4.11 gears. A few years ago I got tired of the higher RPM and put in the stock 3.50 ratio. With the slower RPM build, it seems to take forever for the secondaries to open, at least till I can feel it, seems like about 3000-3500. Should/could it be a little earlier? I’ve read that Holley springs work, but I don’t know if Ford used different springs, only 1 spring, or what Holley spring would be the next step lighter. Also don’t know if PC modified the carb in any way.
    I thought about the mechanical kit but really would prefer vacuum.
    Stock engine except C90X intake.
    Edited 3 times, last by 289kford (August 16, 2021 at 4:42 AM).
  • I have a lot of used 4100 springs and there are several spring rates although I have not checked the books yet to see if Ford had different ones in other applications. I would need to compare them with Holley springs to see if they are compatible, but I do NOT believe that they are as the 4100 spring sort of attaches to the cover. I do not remember the Holley springs doing that.
