5F09K390353 on Ebay NIR
  • Here is a 65 K code fastback listed on Ebay by seller "seferian1965" with a starting bid of $1,000.00:
    This 1965 Ford Mustang is a 2+2 fastback optioned from the factory with a K-code 289cid V8 and a 4-speed manual transmission. Both visible vin number on the drivers side fender and hidden vin number on the passengers side match and are clear stampings.The exterior is painted from the factory Rangoon Red with a pristine white and red interior. The paint and interior are in show condition. Absolutely no chips or flaws in the finish.Panel fit and gaps are perfect, the doors, hood and trunk close perfectly with a solid feel. The chrome and bright work are in exceptional condition with no scratches or flaws. This car is better than new!This K-Code Mustang is offered with the original window sticker, original purchase order, original first print owner's manual, letter from the original owner detailing the cars history, all refurbished receipts, and a clean South Carolina title in my name.This exemplary car has had a rotisserie nut and bold restoration including new steel brake and fuel lines, all suspension components, gas tank, and all brake system components. Please review the videos on Allison Seferian u-tube to see the details of the restoration.The sheet metal is all original, no panels have been replaced or repaired. The entire drive train was been removed so the rust free all original panel undercarriage could be painted back to the original factory red oxide primer including the detailed factory markings.All components including transmission, differential, brake assemblies etc have been rebuilt and detailed to perfection. Front steering and suspension also have been removed, rebuilt, and painted and detailed.The undercarriage is flawless. Has the heavy duty ford 9" differential and differential bumper pad only specific to the "K" code cars. A tremendous amount of effort was taken to make every detail perfect.Tires are brand new double red line radials on styled steel rims.
    The engine has been removed and rebuilt using original components. Has the hipo exhaust manifolds and cylinder heads with the "21" casting numbers.This is the 289,271hp engine(K) code with high performance camshaft and solid lifters. Uses the hipo crankshaft balancer and even has the original performance pyramid engine mounts. Original performance 5 blade cooling fan, shroud, and pulleys are intact. The engine has been painted and detailed to perfection. The original 600cfm manual choke carb has been rebuilt by Champion Mustang carbs of Texas and tuned. (see driving video) All components perform like new!
    These are some for the casting and stamping numbers. more are addressed in the u-tube videos.
    Engine casting #C5AE-6015E
    Cylinder head cast Hipo casting # 21
    Original round alternator ear,Hipo pulley #65AF10A352-H
    Transmission tag# HEH T 013905
    Original Hipo pyramid engine mounts
    Original 600 cfm carb stamping#C40F-AL tag# C50F L
    Hipo dual point distributer casting# C50F-12131-B
    Original Hipo drive shaft measuring 49 23/32 in
    Rear heavy duty leaf springs#C4ZA5556-S fastback
    Steering gear ID tag# HCC AX 5A04B
    VIN tag numbers decoded
    63 fastback A standard interior
    Color J Rangoon Red
    Trim D5 White Red
    DSO 23 Philadelphia
    Axle 5 3.50:1
    Transmission 5 4spd
    The interior is in fantastic condition with no wear at all. The seats, carpet, door panels, dash pad etc are in mint condition. All gauges, speedo, oil pressure, temperature, amp function properly including the clock and tachometer. The AM radio operates as it should and is the original unit.Heater and ventilation system operates like new, heater core has been replaced. Windshield wipers, turn signals, interior lights, dash lights function like new. All windows role up and down like new and door locks function as they should. Original glass is in very good condition. The factory fomoco white floor mats will be included in the sale.
    The trunk is painted body color as from the factory. Spare tire and jack with tools are their proper storage bags. Everything in its proper position and in top shape.
    This car performs flawlessly! Shifts through the gears with smooth transition and of course great power and acceleration. (See driving video on Allison Seferian u-tube)
    I have taken lots of closeup pictures so please view them and use them as part of the description.The car is available for inspections or test drives during the auction. Reserve is reasonable I intend to sell to make room for new projects so bid to win!
    If you need a specific picture, let me know.E bay only allows 24 pictures. I have detailed pictures of the vin and hidden vin, just let me know and I will send them to you.If you have any questions I can be reached at 843 338 1400 Thanks, Robert.
    https://www.ebay.com/itm/274300509308?ul_noapp=true
  • That is one pretty K car.
    The auction for this 65 K code fastback has been ended by the seller March 15, 2020 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • This 65 K code fastback is back on Ebay again because the previous buyer could not come up with the funds. It is now listed with a Buy-It-Now of $58,999.00:
    https://www.ebay.com/itm/1965-Ford-…m4383.l4275.c10
  • Hello Guys,
    I was a member on the old forum and just realized there was a new forum,glad to see this because it was my go to place for all the knowledge that is needed on K cars,I’m interested in this car and wanted to ask opinions from the guys on here that have a lot of knowledge on these cars,does this car look correct to you? Is there anything that is glaring that looks wrong? Any info would be greatly appreciated.
    Thanks,SFred
  • Hello Guys,
    Thanks,SFred
    The first thing that sticks out to me is the 5 dial instruments on a non GT and non pony interior Kar. The Rally Pac is the one for the Falcon type speedometer. These 5 dial gauges require major wiring changes and a dash sheet metal alteration. A thorough inspection would be in order to see what else there is.
  • Hey Fred,
    Thanks for the info,the owner also said that the drivetrain has no vin stampings anywhere,I think I will hang loose and wait for another car to come along,I prefer a GT anyways if I can find one.
    Thanks again for your help!
  • Hey Fred,
    Best of luck with your search.
  • That same car listed on EBAY is equipped with front drum brakes. From what I understand ALL K code cars were equipped with front disc brakes. Am I wrong here?? Any help would be appreciated.
    As Relicdog states, disc brakes were an option on all 65-66 Mustangs except six cylinder cars. They were only standard on GT cars which were required to be A or K code engines. One of my own Kars is a drum brake Kar and I have seen quite a few others this way.
  • In all my years around Mustangs an it’s quite a few I’ve never seen an Dearborn built Mustang with the undercarriage red oxide, I could be wrong but I’ve never seen one until this Kar.
    I, too, am questioning this.
  • This 65 K code fastback received no bids by April 15, 2020 and therefore did NOT sell.
  • This 65 K code fastback is back on Ebay again with a new Ebay seller "streetsideclassiccars" with a starting bid of $5,000.00:
    There's a hierarchy when it comes to 1965 Ford Mustangs, and for the performance lovers, the K-Code HiPo 289 is king. So finding an ultra-desirable fastback that has been preserved and resorted to show-ready standard is absolutely awesome. This significant classic even comes with outstanding documentation.
    Collectors know a K-code Mustang is in the one-percent rarity range of total pony car production from the first few years. So these high-performance coupes are always in high demand. That's why it's extra special to find a well-done one. The panels line up nicely, which adds to a proper presentation of the factory-correct Rangoon Red. There have been the correct investments in this coupe along the way to keep it both looking correct and well-respected. So for example, the paint was resprayed about 10 years ago, but it's condition would make some 2020 restorations jealous. The brightwork is complete and straight on everything from the mirror-like chrome bumpers to the correct high-performance 289 badges. We particularly like how this one retains a classic-style, but it still knows how to announce its extra performance with the right period-correct features. There's a GT-style dual exhaust setup and the styled-steel wheels are Mustang icons. Plus, the double redline tires are nice performance pieces that also coordinate with the paint.
    There's even more period-correct distinction when you open the door. It starts with the cool red and white combo. The trim tag tells us this is factory-correct, and the two colors are quite striking as they interweave throughout the interior. It's especially nice in the details, like the red seatbelts against the white upholstery. And just like the exterior, this all looks clean and complete. Vintage fans will love details, like the working courtesy lights, wood-like trim, and the AM radio that's there for display. Performance lovers will be instantly attracted to the center console with floor shifter, wood-rimmed chrome steering wheel, and the desirable Rally Pac tack and clock mounted on the steering column.
    As much as you'll love the interior and exterior, it's the rare K-code HiPo 289 cubic-inch V8 under the hood that will truly impress. After all, it's the motor that took home the trophies around the globe, and the presentation today has a great look, right down to the decals. While Ford didn't do numbers-matching criteria in 1965, this car has a known history, and the motor is believed to be original to the car. The V8 inhales deeply from the four-barrel carb, and it was even recently overhauled and tuned by Champion Carburetor to keep it this HiPo pony running right. Even the undercarriage photos show you the comprehensive care and investments in this coupe. You see it everywhere from the correct red oxide underside paint to the fresh suspension components that give you confidence when driving this classic. And the H-pipe dual exhaust combines with the control of the four-speed manual transmission to make you the conductor of a high-power symphony while you enjoy this fastback to its fullest.
    The sale come complete with the original window sticker, owner's manual, documenting photos, receipts, owner history info, and more. So to have such a stunning Mustang also be so rare is the kind of treat we all can't resist. Call today!!!
    https://www.ebay.com/itm/1965-Ford-…aEAAOSwD75fh6ZV
  • C6ZZKGT October 16, 2020 at 5:24 AM
    Changed the title of the thread from “5F09K390353 on Ebay” to “5F09K390353 on Ebay NIR”.
  • This Kar was bid to $34,700.00 by October 22, 2020 with 26 bids from 9 bidders but did not meet the sellers reserve and therefore did NOT sell.
  • This Kar is back on Ebay again as a classified ad with a price of $79,995.00 or make offer:
  • This 65 K code fastback received no bids by November 21, 2020 and therefore did NOT sell.
  • This Kar is back on Ebay again as a classified ad with a new lower price of $77,995.00 or make offer:
  • The listing for this Kar was ended by the seller November 26, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
