This used set of HiPo main caps SOLD for $761.50 by
"smine69"
DESCRIPTION:
This is an original set of 289 main caps. They are wider then the standard 289.
"smine69"
DESCRIPTION:
Youch! Dang, how am I going to find a #4 cap!!
This set of used main caps SOLD for $510.69 by eBay seller "5kfast".
DESCRIPTION:
You are bidding on a good set of 289 HIPO main bearing caps that came out of VIN stamped block "5F09K679219". The #1 cap was machined over the #1 and arrow, and someone scrawled the number 1 and an arrow on it. Other than that, there is nothing wrong with the caps. Additional pictures available on request.
This set of used main caps SOLD for $1,500.00 by eBay seller "jkhartley".
DESCRIPTION:
This is a perfect set of 289 HiPo main caps that are ready to be bolted on any 289 and then have lined bored to insure a perfect fit. I have been involved with high performance cars and parts for 30+ years and its time for these items to go to a good home. I've been a member of SAAC and have bought and sold hipo parts and cars over those years.
If parts prices weren't crazy enough, they just keep getting worse! If anyone has any parts to sell, it seems now is a good time!
These used main caps were SOLD for $1,583.00 by eBay seller "rej9".
DESCRIPTION:
This set of HiPo maincaps was SOLD for $2034.00 by eBay seller "mustangtown".
QuoteWOW!!!
DESCRIPTION:
...These are a complete set of five of the beefier large shoulder main bearing caps, numbered 1, 2, 3, 4, and the C30E-A Rear Cap. These HiPo Caps were cast from High Nodular Iron. All 289 Blocks were the same in appearance except for these rare main caps. The 289 HiPo Blocks where just Brinell tested for hardness. All 289 HiPo blocks carried C5AZ-E casting number, and so did many standard 289 blocks. So all you have to get is a common C5AZ-E block, and have it line bored with these main caps and you're home free.
This set of used HiPo main caps was SOLD for exactly $1500.00 by eBay seller "mustang-67".
DESCRIPTION:
You are bidding on a nice matched set of RARE 289 HiPo main caps. These caps are the High Nodular Iron crank caps used on all Shelby's K-Code's and 271 Hp motors. Caps are numbered 1 thru 4 with the rear cap marked C30E-A.
[url=http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=011&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=320116275105&rd=1,1]eBay link[/url]
