does anyone know for sure what the 1965 K code Kelsey Hayes K/H stamped numbers are on the brake backing plates? Might also be Bendix if they are Fomoco plates
Brake Backing Plates 1965
Jim,the KH part number is 48620 as I took that off original car for you.
where is this number located on the backing plate?
iowa
Dave,
On the back, oriented with the wheel cyl to the top the number is at 9 o'clock. Should read 70391. At 3 o'clock you will see the Ford script.
Here is a hint if you need to blast yours. Take some cauking and cover the Ford script and part number. Let this set up over night and then you can blast away. Some times vision can be limited in the blast cabinet or if you have someone else blast them for you then you can rest assured that they will not blast away on the important details that need to be preserved.
Best regards,
Ray
Opps, Dave the number I gave you is for the Shelby backing plates. They have a different offset for the wider drums and shoes.
Regardless, I bet the number is in the same place.
Ray
