August 13, 2008 at 1:12 PM #1 to the number guys and c6zzkgt.i have a speedo cable with this numberC50A - 17260 - Awill this work?bill
August 13, 2008 at 1:40 PM #2 Ford engineering p/n C5OA-12760-A cross references to Ford service p/n C5OZ-17260-A which is the correct replacement for 64-66 Mustangs V8 engines with 4 speed manual transmissions. The casing should be 64 15/16 inches long.Jim
August 13, 2008 at 3:50 PM #3 Bill,Most likely the cable will have a thinnerrubber sleeve instead of the original foamsleeve. This means the hole in the fire wallwill be too large. I found an old cable withfoam and replaced the rubber sleeve with that one.This issue has been discussed on another treadrecently./Bo
