Engine assembly date query
  • Hi all.
    Forgive me if this has been asked before.
    What does the letter after the machining date mean? IE, what does the R mean in 5C11R?
    RP
    Edited once, last by rene.pilat (February 17, 2008 at 11:22 PM).
  • It's possible you are referring to an engine's assembly date, which is stamped on the boss located at the left front side of the block just aft of the water pump...If that's the case, the last letter is an inspector's id code.
  • Are you referring to the stamping on the drivers side head surface extension or the bottom of the block (oil pan machined surface at the rear)?
    Oil pan surface = machining
    Head extension = assembly
    Believe only the assembly stamping includes any dates and mentioned above
    Edited once, last by J_Speegle (February 17, 2008 at 9:33 PM).
  • Quote from SixT5HiPo
    Yes, that's what I was referring to, thanks.
    RP
