I know I've posted about the clutch rod seal in early '65s before, but now that I'm farther along, can someone post pictures or hole diameter info on the early '65 clutch rod hole versus later ones? I know the seals were different. A picture of an early style seal would be helpful, too.
In my case it appears that someone tried to modify the firewall hole to fit the later '65 & 66 rod seal, but ended up butchering it. So they instead mounted the seal on a piece of metal and screwed it onto the firewall. I'd like to try and "un-butcher" my firewall, though I'll probably use the later style seal.
