Hydraulic Clutch
  • i did an advanced search and got zero hits!!
    so will start a new thread here to address this issue.
    1st, has anyone used this setup on their K car (cringe)?
    other than Modern Drive Line n Bruce
    i haven't found any detailed instructions or videos
    on how to install such a devise on a 65 or 66 mustang
    bruce's instruction sheet is fairly difficult to decepher
    we will be putting one on my son's '66 coupe C code
    so i'll keep you updated
    thanks
    iowa
  • His intention for the hydraulic clutch is that he is putting a T5 in his sons car. I have done several of the T5 conversions and I used a cable instead. I did not particularly like the cable but it was easier than a hydraulic setup.
  • Quote from C6ZZKGT
    just curious, a Z bar won't work with a T5 ?
    Z.
  • i plan to install the regular clutch setup in my K kar
    don't worry about that!
    this is just for my son's T5 setup
    i just wondered if anyone here HAD used it on their K kar?
    it doesn't seem so as i didn't get one hit as mentioned above!!
    iowa
  • Quote from iowa
    this is just for my son's T5 setup............."
    iowa
    not worried, just curious if the Z bar works with a T5.
    I do know you can use a stock bell housing (w/ adaptor plate) with a T5, so it seems that keeping the z bar, combined with a Centerforce I, would be a pretty easy-to-operate clutch system.
    Z.
    Edited once, last by zrayrichter (January 28, 2011 at 10:36 PM).
  • Z Ray, I did a couple of them, by customer request, with a cable and the T5 type of bellhousing setup. On the last one I did use a stock bellhousing and adaptor plate for the T5 with a stock Z Bar type of linkage. It worked much better than the cables.
  • like i said
    we will set it up both ways
    if one uses the regular clutch linkage
    one has to drill two holes in the T5 Bell H
    and....if one wants to use the hydraulic clutch
    one needs two holes in a different location in the T5 Bell H
    i had Bruce at MDL drill all 4 of these holes
    so we will have these two options
    will let you know how it works out
    and with method we final decide to go with
    iowa
  • One key point to installing a hydrualic clutch on your car. You will have to drill a least two holes in your firewall to mount the clutch master cylinder. I am sure there different types and applications, but the ones i am most familiar with have the master cylinder right below the brake cylinder. If you are against drilling holes in mustangs, this alone may help make your final decision.
  • i would never do this to my K code
    but am not opposed to doing it to my son's C code coupe
    ....but we haven't entirely decided yet
    we did put hipo exhaust manifolds on it
    and are still thinking about using the regular
    clutch linkage and set up.....
    iowa
  • Hi, at risk of being accused of K abuse my car has a hydraulic clutch setup at the moment until I can obtain the correct spec C4 trans. It has a later V8 Falcon bell housing to suit hydraulic clutch. The pedal support and firewall has been drilled to suit the master cylinder. This was already done to my car when I got it many years ago but I have done this conversion on a 64 and 65 Futura coupes.
    This is easier to do with the pedal support out of the car. You have to drill mounting holes for the cylinder and put a hole for the master cylinder to go through. Weld two nuts on the pedal support for the m/c to bolt to. With the cylinder mounted and push rod in place move the clutch pedal across the push rod while keeping the push rod on the same plane as the brake one to work out a centre line/ position to put the hole for the push rod to clutch pedal mount ( use a brake pedal bolt which allows rotation) . Drill a suitable size hole for the bolt. Re install the pedal support and mark out the hole on the firewall for the m/c 3 holes -2 bolt hole and centre hole. Drill out these holes and mount the cylinder. I think the bell housing mods have been covered.
    In a nut shell you are trying to replicate the brake cylinder/pedal relationship for the clutch pedal and cylinder.
    I hope this helps.
  • we are going to use the standard clutch linkage setup
    but are not sure the hole for the equalizer bar pivot
    is in the right place.
    we have an engine plug by the front arrow
    and thot that the rear arrow indicates where
    the placement aught to be
    is this true?
    we're wondering if this is a 302 block
    and if it is,
    how does one hook up the equalizer bar to the engine?
    thanks
    iowa
    Edited 2 times, last by iowa_old (February 6, 2011 at 9:23 PM).
  • I'm 99% sure you can buy a little adaptor that bolts to the block (for using the pivot stud) from the major mustang supply houses
    Z.
  • That is correct, he should have said '100%'.
    Z.
  • I looked for it in the npd catalog, but missed it somehow.Would be surprised if they didn't carry it.
    Just tell them you have a newer engine block and want the adaptor bracket thats lets you use a Z bar with it.
    Z.
  • the starter flange measures 4 1/8 outer dia
    the hole in the blocking plate is a smidge under 4 1/8 dia
    what is the best way to enlarge
    the blocking plate starter hole?
    thanks
    iowa
