• Help
    I am trying to get a hold of the correct stock clutch. Now bear in mind I am across the pond this is not easy.
    Both NPD and Summit sell RAM clutches. I ordered a kit from Summit shown in the catalogue as having the correct 8 spring hub with organic friction material. I checked with Summit that the disc was as per picture and they confirmed yes it was.
    So I get a 6 spring disc.
    I cant seem to find out if RAM do an 8 spring organic disc.
    So anyone know a part number and source for a correct clutch kit with organic 8 spring friction plate ?
    Thank you.
    PS I assume I am right in trying to go for an 8 spring plate ?
    Edited 2 times, last by cobraboy (January 19, 2011 at 12:58 PM).
  • Mark, The 8 spring version is the correct one for your Kar. I just sent you an email on this.
  • there are places over here that have good reputation for rebuilding Hi-Po clutches. Do you have the old Hi-Po clutch that might be rebuilt?
    this contact info might not be up to date:
    Arizona Brake & Clutch Supply, Inc.
    2211 N. Black Canyon Highway
    P.O. Box 6369
    Phoenix, AZ 85005
    602-256-7966
    602-254-1283 fax
  • Thanks Ray
    I do have a correct old one. I dont know the costs involved in sending stuff back to the US for rebuild. I sent my Rally Pac tach back and that was OK. But a clutch disc is a lot heavier.
    Besides Customs get all excited and want to charge you for getting your own stuff back.
    I am receiving help from this forum on the matter.
    Cheers
    Mark
    PS had to put my pic up as its you :)
    Edited once, last by cobraboy (January 18, 2011 at 3:29 PM).
  • +2 on Arizona Brake & Clutch!!!!! I had THE original 8 spring disc and pressure plate from my K engine and sent them both to them for rebuild, came back beutiful and perfect in every way!! as I recall both pieces were around $150.00 including shipping both ways, that was over 2 years ago. You will feel so much better like I do each time you drive your Kar with the original setup in it!!
