Cutch fork return spring
  • Hi Fellas would someone please tell me where the forward end of the clutch fork return spring is supposed to hook on to as I am having a dim moment and cannot seem to find a suitable location without it rubbing on the exhaust. I am beginning to think I may have a tab or bracket missing. Thanks
  • somewhere on the lower part of the left shock tower is a hole that the spring attaches to. this is from memory. i am 90% sure about this answer. goodluck
  • Cobraboy,
    You have the long spring, correct? The short end from the coil
    is treaded into the larger hole in the shock tower and the
    point through the smaller hole. The long end from the
    coil goes through the end of the clutch fork.
    The two holes on the shock tower are located just above the
    front driver side frame. Your car has left hand steering,right?
    If it's right hand steering, I am afraid I can't help you.
  • Great I have found those and fitted the spring which is the correct one. It is still slightly bent round the exhaust. I must have a pipe that is formed slightly wrong. I will keep an eye on it, ideally the forward end needs to move toward the engine to miss. Thanks
    Edited once, last by cobraboy (March 6, 2009 at 11:08 AM).
