Hey all.. Picked up the new fastback from Boulder last weekend. It has a few little issues, but overall it seems to be a pretty tight Kar. Hopefully somebody here can shed some light on the first issue I've come across. Upon closer inspection to find an annoying squeak when the Kar is idling, I found that the bottom of the exhaust manifold is in contact with the top of the motor mount on the left side only. I'm pretty sure it's not the original block, but is has the correct hipo manifolds (header style). The engine sits nice and level and there seems to be the correct amount of clearance between the exhaust and the clutch linkage and everything else lines up nicely. It looks like the manifold actually has a divit cast into it to clear the mount, but it's making fairly heave contact with the top end of the metal plate right in that spot. I'm guessing the mounts (or just the left mount) is incorrect. The numbers on the mounts are as follows (at least as best as I could make out under limited lighting):
Right - C30A 6A080-B
Left - C30A 6C041-B
I would love to hear any thoughts on both what these mounts were for and ideas on how to solve the clearance issue.
