Tiger- small oil filter
  • My restomod convrt is really crowded around the oil filter location, and I understand the Sunbeam Tiger has a small, dimensionally, oil filter, and I am trying to find a source, anyone:?: Pease?
    Edited once, last by SixT5HiPo (March 23, 2008 at 3:41 PM).
  • Do you need for the filter to be narrower or shorter? One choice only please.
  • A shorter one is the Motorcraft FL-300 .I use this on 2 of my cars that have 302's in them.Fram number is PH8A if you want to go that route. It too is shorter.These are both the standard diameter though ,just shorter
  • The narrow one is a Motorcraft FL295 but it is not shorter, only smaller in diameter.
  • The Fram PH16 is even a little shorter than the FL-300.
    Or you could go with a dual remote filter set-up if you want to get really tricky.;)
    Edited once, last by toolbox (March 22, 2008 at 2:55 AM).
