Today I was looking at a Hipo engine. Instead of the screw in studs they were pinned. I had never heard of those before. The same fellow also had a standard 289 head with a 20 casting . I was always told 19,20&21 nubers refered to hipo heads. Any comments?
New to me
Unicorn -
April 5, 2011 at 9:56 PM -
Closed
if the heads do not have factory cast in spring pockets and factory screw in studs they are not K code heads they are modified standard 289 heads, Chuck.Quote from UnicornToday I was looking at a Hipo engine. Instead of the screw in studs they were pinned. I had never heard of those before. The same fellow also had a standard 289 head with a 20 casting . I was always told 19,20&21 nubers refered to hipo heads. Any comments?
You were not looking at a HiPo 289...or at least not a complete one.
Do you have pictures of the "standard" head with the 20 casting?
Use to pin rocker studs on Street Stock dirt track cars that had to use stock heads, that was an allowed mod but we couldn't use screw in studs.
I will get a pic of the 20 standard head and the pinned head. The holes for the pins look factory uniform. This dude has some interesting parts including some very rare Ford 289 pistons. 1 of 50 sets made.
