• In the book, "How to rebuild your small block Ford"
    there are lists showing the various parts and the
    one you list is only shown as a standard 289 block,
    not HP.
    Edited once, last by SixT5HiPo (July 26, 2009 at 10:35 PM).
  • Quote from manleytom
    Can a 1967 K code have a block stamp of C6AE-6015-C 6M21
    Thanks! Tom
    By 1966, 289 V-8 production was taxing the Cleveland Foundry to the limits, and it wasn't keeping up with the demands. To address this problem, Ford added the Windsor Foundry to supplement Cleveland production, and uses a new C6AE-C casting number for the Canadian blocks. The 289 HiPo engines were cast and assembled only at the Cleveland Foundry, and these Cleveland blocks continued to use the C5AE-E casting until the end of 289 production there...
  • Quote from BoS
    not HP.
    That's right, Bo, because a C6AE-C block is a Windsor Foundry casting number, and Windsor did not produce the 289 HiPo engines.
