spare tire hold down
  • I'm replacing the rear frame rails/trunk floors right now and will need to transfer the tire hold down to the new trunk floor. My kar is a January '65 Dearborn coupe and has the early style carriage bolt hold down.
    Could anyone post a picture of how this hold down should look? Right now, the bracket looks slightly 'deformed', maybe from someone overtightening the bolt...or maybe it's supposed to look that way, I don't know. Before I hammer it flat I'd like to compare it to a picture of a good original.
  • Thanks!
    Another question-
    The original floors are flat, with a small raised square over where the spring shackle mount is. The repro floors have a small ridge formed around where the bumper bracket goes, and three "lima bean" shaped stampings just forward of the spare tire mount. What are those for? A place to put the jack on later models?
    I'm probably going to try to shrink them and hammer them flat to match the original better.
  • Here is a picture of my trunk panel with the spare tire hold down.
    Make sure you weld it in the right spot cause the tire won't fit properly.
    Dave V.
    Edited once, last by csxeng (July 11, 2009 at 4:48 PM).
