My 65 K GT fog lamps point up about 10 deg. Makes it impossible to drive with them on since they are blinding. Seems like they should be horizontal or down about 10 deg. I don't see how i can adjust them down sufficiently without shimming. Has anyone solved this problem? Anyone have pics of a proper installation they can post?
Fog Light Alignment
Unless something is bent or your Kar is sitting high in the front, I have been able to adjust these lights successfully. Do you have genuine Ford lights and bars?
The car's a genuine GT but i don't see a part number stamped on the bars.
The lamps are adjustable, not the bars.
Turned out i had a 66 hood latch bracket. The way whoever installed it made it fit was to remove the fastener under the horse bezel and pull the top of the grill back to align with the attach holes. This moved the verticle alignment of the fog lights up so far I couldn't adjust it out. Replacing hood latch bracket with proper 65 version should solve the problem.
This turned out to be an easy solution to a subtle problem.
