65 rear housing ?
  • My 66 has what I think is a 65 rear housing. It does have a smooth back to it, but should there be any casting numbers inside or out of the housing? I know the springs are incorrect they are C7ZA 5556 AR. The housing does measure correct at 52 5/16".
  • Depending upon when your car was built in '66 your housing may be correct.
    I've never seen numbers on the housings - but I've only seen mine and 2 others - all '65s - one was even from a '65 GT350.
    Ford did a running change on many parts at various times in Mustang production - they changed to the different rear housing and dropped the special HiPo only motor mounts in early '66 - so if your car was built early in the model run it may have had the round back housing instead of the later style. Having the special HiPo motor mounts would be a good indicator of early production too - but your build date would be the best source - along with asking someone with a car built close to yours what they have installed.
  • According to the Ford parts book, the change to the later style housing was supposed to be 10/1/65 although I am sure that there are exceptions to this at different assembly plants. The Hipo motor mount change was listed as 11/1/65 and that also can vary.
  • Being as it is probable that you do not have the original 66 housing, you might check the axle tube diameter to make sure that what you have is not a clone. If it is not, there will probably be someone on this forum that would like to trade.
