Installing Intake Manifold with Cork Gaskets?
  • I'm ready to install my aluminum intake on my 67 GT 350. Was going to use Ford intake gaskets. What about the two end cork gaskets, if I run a small bead of sealant on the top and bottom of them and at each corner, will that work? There is also the option of omitting the cork gaskets and running a heavy bead of sealant. If the cork gaskets will seal, I would rather go that route to keep the original look. Any comments on this? Randy
  • I glue the cork gaskets to the block with 3M weather strip adhesive. Let set. Then put a thin coat of silicone on top and dabs at the corners. The weather strip adhesive keeps the cork in place till the silicone sets.
    Larry
  • I've always just set the cork in place (no sealer) and put only a tiny dab of sealer on each corner. I've always had good luck with this method on SBF.
  • Quote from toolbox
    That usually works only if the engine is not in the car. That rear gasket can be a rascal if the engine is in the car
