I just wanted to get a consensus for the proper finish on Ford shifter boxes. I think the correct finish is Zinc. I originally thought cadmium, but the old finish was hard to blast off and cad would have been easy. Thanks, Joe.
Shifter Box Plating.
Phosphate and oil is what I remember being on the ones I have seen.
Yes, the shifter cage was usually zinc plated. That's how I do them.
The cage and levers inside the cage are zinc, the shifter rods are zinc phosphate & oil.
Thank you for the help. I have rods with phosphate and the spring on the box is phosphate. I was also going to do the levers on the trans in zinc. Thanks, Joe.
