Does anybody out there have the special 12 point bolts that hold the 4 piston calipers together? I need 2 of them. Thanks, Doug
65 66 K/H brake caliper bolts
Have you checked with AMK?
They have just about every bolt Ford used on the Mustang.
Thanks. I will do that. I didn't think they would have them but I will check. Doug
Another source I've used often for piece parts like that is Stainless Steel Brake (SSBC).
Thanks guys. I think I found some. Doug
Doug, So where did you find your bolts?
I got the bolts from Jim Cowles at Shelby Parts and Restoration. He has repro and some original. http://www.shelbyparts.com Check also with
http://www.chockostangclassicmustang.com He thought he might have some.
Doug
