Mustang Engines and Parts
  • For sale;
    '65- 289 Engine block; casting# CSAE-6015-E; bored .030; new cam bearings; $400.00 build date 5F18 T.
    '66-289 cylinder heads (bare); non-HIPO casting #C60E; Bare; both for $200.00
    289 HiPo Crankshaft; NOS; in original box; C3OZ- 6303 B $400.00
    641/2 -66 Mustang Motor Mount brackets; 4 pcs; $100.00
    Small block timing cover D4--part# and timing pointer NOS; $85.00
    Dual point distributor Part # D3OF-12127-FA (one vac advance screw is broken); $100.00
    1994 5.0 Roller Block; NON - SVO New in crate; $500.00
    Vacuum Advance Diaphragm for Ford distributor D5AZ-12370-B; new in box; $40.00
    Located Unionville PA 19375 PH. 302-593-9387
    Edited once, last by jgroome_old (February 23, 2009 at 2:48 PM).
  • Don't believe any of this stuff is Hipo related as it's in the standard parts section.I e-mailed him when he first placed the ad before anybody read it or responded asking about crank and got NO response?
  • Quote from RPM
    Since the body of the original post does not contain the seller's email address, you probably attempted to use the email link found in the member's information section. Unfortunately, that email function hasn't worked for some time now due to a "server change" beyond our control which has unintentionally disabled site-generated emails...In the meantime, the PRIVATE MESSAGE function is working just fine, and it enables MEMBERS to communicate through the site discretely.
    So far, the email problem hasn't been completely solved yet, but it is under investigation. You can read more about it HERE.
