Am looking for NOS axles seals part number C1UW-1177-A3 if anybody has any?
Wanted:Axle Seals
Have you had any luck with replacement seals?
Haven't really looked for replacements as I thought finding a NOS set would be easy?
The Ford ones are kind of hard to find. You'd probably be better off buying replacement seals.
when you buy NOS seals more than likely they are dried out as they are at least 25 years old since they serviced them
Can anybody give me the correct part number for these seals as the number I gave is off the part and not the box part number?
The actual Ford part number is a C1UW 1177 A and the original that you have actually has the part number on it which is unusual. The C1UW number is usually an engineering number and the part number would have been a C1UZ. This is a rare exception to the rule. I have NOS ones in the Ford box where one has the Ford C1UW number and others have a National seal number of 51322.
Well I was going thru some NOS parts in shop and found 2 sets of NOS ones so if anybody else wants a set I can fix you up!
