65 Hipo angle mount brackets
    We removed an original stud and machined some to original specs. The fine thread is a bitch
    Many years back, we repaired a damaged stud by replacing it with a bolt machined to fit. You might want to try that.
  • Only problem with that is the bolts are welded in before the two halves are welded together. To properly get the stud out the pieces need to be split apart. the stud cant be removed without doing that. Ive done it but we had to bend the heck out of the bracket to the point of almost ruining the bracket and the stud gets wrecked in the process. Its physically impossible to install the stud without wrecking it when the part is together
  • do you mean REMOVE the stud without wrecking it? I'm confused <img src=images/icon_smile_evil.gif border=0 align=middle><img src=images/icon_smile_evil.gif border=0 align=middle><img src=images/icon_smile_big.gif border=0 align=middle><img src=images/icon_smile_big.gif border=0 align=middle>
    the way they are made originally they arent meant to be restored. If you try to replace the stud you will wreck it
    I'll be sure to tell Paul and Ron, the machinists, that what they did was impossible and that they will have to un-do their work - although it may be difficult as it was done in 1994 or 95 to a long gone 65 'K' hardtop.
  • Sure , you can restore them if you throw enough time and money at them. cut them apart on the weld. press out the junk stud. machine up a new stud, weld it in, weld them back together. My point was that the stud cant be removed without doing this. Its too long . Ford made these to be replaced, not restored.
  • So if you make brackets from raw materials, why can't you choose an appropiate bolt, machine it to the correct form and fit, install it in place - instead of making a stud from scratch? And yes, I've modified 5/16-18 carriage bolts to include a lead point to use on 64-66 batttery trays.
  • Head on stud is 7/8" and its round , thread is 3/8 fine with alignment knob on end. Sure you could cob a hex head fine thread bolt in there but it would have threads all the way to the end and no alignment knob. We're trying to make a quality authentic part here. Other than the Laser cutting its pretty much dead on.
