Looking for a yoke. I dont know if the year matters, but I have a June 1966 kar. I also need a complete shifter with rods.
Thanks Brian
Thanks Brian
You might want to contact Bill Heally for a correct shifter, lots of folks on here have delt with Bill, he is the best!!!
Would anyone have dimensions and pics of a third member yoke to help me in locating a correct one?
Thanks Brian
Hi Brian, I am trying to find out the same info on the the yoke for my Kar.
Looking at Mustang 64 1/2- 70 Restoration Guide by Tom Corcoran & Earl Davis I think the yoke should be the type 2 listed on page 238 p.n .C3AZ-4851-L with a total yoke length of 5-1/16" which is about 130mm.
I am awaiting some clarification on this matter myself and will post the results for you if I find out. In Adelaide it is alot harder to find another Kar to look at than in the USA.
Cheers Zed
Hi, the yoke should be part number C3AZ-4851-L with a length of 5-1/16".
Mustangs V8s are using the 1260 (C3AZ-4635-C front and C3AZ-4635-D rear). Fairlanes also use the 1260 U-joint exclusively.
Thanks to Bob Mannel for his help
Zed, Some of the standard 1965 289 Mustangs used the Ford style (outside clips) U-joints with the numbers you gave of C3AZ 4635 C (front) and C3AZ 4635 D (rear) however most of the standard 1965 289 Mustangs used the mechanics type (inside clips) with numbers of C5DZ 4635 B (front) and C5DZ 4635 A (rear). The Hipo cars all called out for the mechanics type (inside clip) C5DZ U-joints. This is according the 1965/72 Ford Master Parts Catalog. The C5DZ U-joints do fit the C3AZ 4851 L yoke.
Hi Fred,thanks for the info. I am not sure how to determine the yoke type I need. I was told the Mustang 64 1/2 -70 Restoration Guide has the right part number but gives the wrong measurement for the U-joint ie 1310 type instead of 1260. Do both types of U-joint fit the same yoke? Your help will be appreciated as I just got a 1310 style yoke/flange in the right length for my Kar. Do I need to keep looking for another yoke?
Thanks Zed
Hellow Brian, I have the yoke you need. 626 4887504, Michael
Zed, Both types of U-joints fit the proper yoke.
Hi Fred, could you please contact me on [email protected] so I can send you a couple of photographs of what I have to confirm if it is correct. I would place a ruler across the U-joint face etc.
Many Thanks Eddie
Eddie, I just sent you an email.
