Hello,
I'm new here so don't ridicule me too much. I just acquired a HiPo 289 to use in a Sunbeam Tiger I'm restoring. Now I'm thinking the engine may be more valuable to someone with a K code Mustang.
The story goes that the engine was built by a gentleman named Skip Miller who drag raced it in a Ford Falcon. Shortly after he built it, he bent the frame of the Falcon and took the engine out.
It's not complete. I discovered the main caps are not HiPo and the block may not be either (C5AE-6015E 4L7). The crank is still original dimensions (verified at the machine shop I took it to). It has the little counter weight, HiPo dampner, and timing chain. The rods are 6 HiPo and 2 Boss 302. The heads have been ported and have 351W size valves. It has a Sig Erson cam and solid lifters. The pistons are TRW 2249 high compression (12:1 I believe).
Anyway, what I really am looking for is a 289 that can rev at least to 6500 and make 300+ HP on pump gas. If anyone has a fresh longblock to trade or wants to make me an offer I am open.
Bob (bobdixon at frii dot com)
