Anyone have an original PCV valve for a 65 they want to part with? I have an NOS AC valve with the threaded end. I don't think it's correct for an early 65 though.
Bill
Bill
Depending on when you car was assemblied Ford did use AC brand PCV valves for a period.
Sure Mike would fill in with a picture ![]()
I think Bill is referring to the hex base valve with a non-threaded hose connection. These are very hard to come by. One OE supplier was AC, I don't remember the other, but both are stamped with a C5AE engineering number. The threaded C4 valve is much more common and will work since once the hose is connected you can't tell the difference.
The car was built in December, 1964. It has the brass elbow with the PCV valve screwed in. Not original as the intake, carb and distributor were stolen in 1978. Everything replaced with proper date coded stuff, only thing left are a few small, impossible to find items like the correct PCV valve and a throttle return spring.
Bill
If you check in Bob Mannel's book you will see a well detailed photo of the various valves Ford was supplying. I found mine in the wrecking yard on a 64 F series pick up with a 390.
I found my original C5AE PCV valve in my old tool box.
Must have got it with me when I moved from Sweden more
than 20 years ago. The spring didn't move inside so I
put it in a solvent bath for a couple of days and that
did the trick. Wish I could do the same to myself
and unfreeze stiff joints.
The nice thing about those original C5AE valves (C4 as well) is you can take them apart and service them, they are held together with a spring clip. I found an old dirty used one on ebay for a few bucks two years ago, disassembled it, and sent the housing in with a bunch of other stuff to be zinc plated. Looks better than NOS now.
QuoteI found my original C5AE PCV valve in my old tool box....
Hi Bo, out of curiosity is your original valve the AC type or other style? I've seen Mark's original from 5S284 and it's an AC type. Thanks, Dave
Getting back to my origial question, does anyone have one they want to part with? My NOS Threaded AC unit is available. I also could use a chrome oil cap stamped FoMoCo with the vent hose fitting that goes to the air cleaner. Anyone know anything about the Re-Po's that Branda sells? Most likely have to settle for one of those.
Bill
Bill, I've only seen pictures of the oval script Scott Drake oil caps, I assume this is the one Branda sells as I believe Drake is the only supplier. IMO the script isn't quite right plus the top doesn't have the two spot weld "dimples" originals do. I'd also like to hear opinions from anyone who has actually seen these in person.
RE: the PCV valve, have you tried J.D. Larson at All Classic Motors?
Dave,
I'll take it off the car later tonight and have a look.
Dave,
Just took the valve off and it's marked
C5AE-6A666-B-C.S.CO
Dont' know the significance of the C.S.CO
but it could be the same company that made the
Fan's.
Thanks Bo, The C.S.CO valve is the other supplier I was thinking of. Interesting that yours and Mark's cars have different original valves being so close sequentially but probably just a case of what was grabbed off the parts shelf. Dave.
Dave,
Sorry if I did mislead you with calling it original
to my specific car. I am not 100 % sure if I
took it off my 65 and put into my tool box
or if I got it with me from Sweden when I moved
over 20 years ago. Probably the latter. What's the
difference between the AC unit and the C.S.CO unit?
Also, wasn't this a service item that would either be
cleaned or replaced at a specific service interval
by the gas stations/repair shops performing the service,
i.e. how can anybody be absolutely sure it's original to
their respective car if they weren't the original owner?
Hi Bo, I'll post pics of the AC and C.S.CO valves when I get back in town on Sunday. You're right, hard to tell if yours is original but since that type could be serviced it likely is. The production window for the hex base, nipple hose (non-threaded) connection C5AE valve was pretty small which is why they are so hard to find today. If your original was replaced I would strongly suspect it would have been replaced with a later C6AE round base valve which came into production later in 66, all the later types are not servicable. Bob Mannel's book has some great pics of the different styles. I also have a weird valve with the corrrect C5AZ Ford part# that has a C7AE engineering number. Not sure what's up with that since AFAIK the C5 valve was superceeded by the C6 valve. Dave
PS. Bill, you might also try Jim Cowles for an original valve. He bought a large lot of these last year on ebay. Don't remember if they were used or NOS.
The NOS valve on the left is the AC type and came in the shown box. The valve on the right is the other style Bo mentions.
Thanks Dave,
Yes, the one to the right looks like mine
including the notches on the hex edges.
The one pictured in Bob Mannel's book is the
AC type to the left in your picture.
In my shop manual from 1965, they recommend the
PCV valve to be replaced at the recommended interval
and not to attempt to clean it. In my Swedish owners manual
they recommend it to be cleaned at every 10000Km.
