would it be okay to
put a HiPo fuel pump
on a regular 289 engine?
iowa
would it be okay to
iowa
won't hurt, won't help.
Z.
i'm not sure what you mean
when you say it won't help
iowa
Quote from iowai'm not sure what you mean
iowa
Sorry for the cryptic response. I mean there is no performance advantage to using a Hi-Po pump on a stock, non K code, 289.
Better, IMHO, to sell it. or store it for the day when you can use it on a genuine Hi-Po engine.
Z.
If the regular 289 is a built motor that can rev like a K motor, you might be better off with a K-style fuel pump.
true.
I was taking "regular 289" as meaning a stock A or C code, but there isn't much detail from the OP to go on.
Z.
A hipo pump is an expensive item. You can get reliabile fuel delivery to a non-hipo motor through other means at a lower cost.
He is probably talking about the NAPA fuel pump that is listed for the hipo.
