Motor Mount Stud Part Number Question
  • There is another number in brackets listed for that bolt it is
    [BB-838-K]
    The plates with the frame stud are made of two parts welded together
    The upper part number is C3OZ-6046-A same for L and R
    The lower left hand is C5ZZ-6029-A
    The lower right hand is C5ZZ-6028-A
  • Quote from RPM
    Wow,that bottom piece didn't come from Ford with both pieces welded together under one part number?
    The upper assembly dropped straight down into the lower (frame)bracket. It therefore could not be one piece. All the part numbers are listed in the Hi-Po registry except the hardware items:
    - special bolt - 379891-S2 (2 ea);
    - washer to lower bracket - 353472-S8 (2 ea);
    - nut to lower bracket - 34421-S8 (2 ea);
    - bolt to frame - 372993-S8 (6 ea);
    - nut to frame - 377704-S8 (6 ea, although others were authorized).
    All the items are available at AMK.
