As some of you may know, I'm currently breaking in a motor I built for my Sunbeam Tiger in my HiPo car.
Part of this little project originally was to give me the opportunity to detail my HiPo motor while it was out of the car. Well... It turns out it needs more than detailing, and the motor is completely disassembled, and ready to go to the machine shop.
The cam and lifters are HOSED. I plan on putting a Comp Cams Ford 289-302 Nostalgia Plus N+271H Cam, part# 31-670-4 in it, as I did with the motor I built for the Tiger. I REALLY like this cam, and I'm sick of messing with mechanical lifters, quite frankly, so a change is in order.
This cam is available in a "kit" which I bought for my last motor, that comes with springs, keepers, seals, lifters, and a timing chain. I called the Comp Cams help line with 2 simple questions, which the bonehead who answered the phone (after me being on hold for 20 minutes) couldn't answer. Some of these "experts" amaze me. He knew NOTHING about HiPos. All I got from him was "A 289 is a 289 is a 289." Finally, I just hung up on him, since I know I can get better answers here. Here goes:
1. Does anyone know of a roller timing chain that has the thinner crank gear to accomodate the HiPo oil slinger? If not, can I turn a roller crank gear down to get the proper clearances for it? I'm tempted to buy a roller set, and just put my hatchet and gears in a box on the shelf.
2. Comp Cams says you need to change your springs when using this cam. "Mr. Helpful" wasn't able to tell me if the HiPo springs are adequate to use, since "All 289s are the same." I would imagine the stock HiPo springs are more than okay for this application.
The dollar difference is substantial.
Any input?
