• Thank you Dan there is a flywheel listed on e bay that looks like it has a crack in the ring gear . i once had a ring gear with a small crack just enough to make it slip on the flywheel when starting the engine, it sounded like a bad starter grinding
  • I have some NOS ring gears and I will try to check on them tomorrow. I do not remember having any welded areas on the ring gears when I was heating them to remove and replace the ring gears. I saw that flywheel and chose to pass on it.
  • I have not seen any weld or seam in a ring gear not to say some did not, the issue i had on a 70 boss 302 was the ring gear started slipping on the flywheel i noticed that the engine was turning over much slower than normal when cranking along with a grinding sound, the ring gear actually cut into the flywheel much like a lathe would, metal filings were found inside the bellhousing from it i had to replace the flywheel as a replacement ring was to loose a fit.
