Hipo 4 Speed Flywheel
  • 65 Koupe early San Jose Phoenician Yellow 4 speed
    Edited once, last by C6ZZKGT (March 24, 2019 at 4:36 PM).
  • Here is an Ebay auction for a used Hipo 4 speed flywheel by Ebay member "magmustangs" with a Buy-It-Now of $699.00:
    1963-1966 Ford Mustang, Fastback, Coupe, Convertible, GT, Shelby GT350, Cobra, Fairlane, 500.. 4 SPEED MANUAL TRANSMISSION FLYWHEEL For 289 HIPO Engine and 10.5" Clutch. 160 TOOTH Ring Gear. This is an ORIGINAL FORD PART. Casting Number (FoMoCo) C3OE-6380-B and dated [4K9]. Removed from a 65 Mustang with 289 HIPO and 4 Speed. This has the original Orange paint daub, which is fading, and also has the Brinnell hardness test mark. . The Flywheel is in Great Condition.. The Clutch Surface Looks Fine. You should have the surface cleaned-roughed up before installation at a minimum. It is 50+ years old and so it might need turned-resurfaced. It does show some stress marks because it is an old original. If you have high expectations for a perfect original flywheel then please pass this one by. No Guarantees on this flywheel. No heavy wear. No Rust anywhere. Has Great Metal. There is some wear on the ring gear teeth. The ring can be replaced or turned around. Has a Natural Metal Finish. . Overall this is a Great Original 289 HIPO Flywheel. IMPOSSIBLE TO FIND ORIGINAL.
    https://www.ebay.com/itm/1531851376…e=STRK:MEWAX:IT
  • Is that flywheel even usable with all those heat cracks?
    One of the scariest rides I ever had was being shotgun in a car that blew a flywheel on the street at about 70 MPH. The flywheel took out the hydraulic brake lines, fuel lines, part of the frame, ballooned the dash, knocked down a small roadside fence, dug a small crater in the asphalt street and set the transmission down onto the parking brake mechanism. We were going slightly down hill at 70 MPH with the driver wanting to jump out. I am grabbing the steering wheel from the passenger side and scrubbing the tires into the curbs trying to slow us down. All this time I am trying to convince my friend to not jump out. We did this for around one mile before I was able to finally stop the car.
    What does this have to do with the current question? The flywheel in the car was one that I took out of my car because I felt that it had too many heat cracks and I was afraid to use it. I guess that I was correct in my original judgment but failed in my second judgment by riding with my wild, power shifting friend. ;)
    All that said, the cracks in the flywheel here are not nearly as bad as mine was and may be able to be surfaced out. Would I spend $699 to find out? Probably not.
    Edited once, last by C6ZZKGT (March 23, 2019 at 10:10 PM).
  • This used flywheel received no bids by March 23, 2019 and therefore did NOT sell.
    This used flywheel is back on Ebay again with a new much lower starting bid of $200.00 and a Buy-It-Now of $300.00:
    https://www.ebay.com/itm/Ford-289-H…&orig_cvip=true
    Edited once, last by C6ZZKGT (March 31, 2019 at 4:05 PM).
  • This used flywheel is back on Ebay again with a new much lower starting bid of $200.00 and a Buy-It-Now of $300.00:
    This used flywheel sold March 31, 2019 on Ebay for $227.50 with 2 bids from 2 bidders.
  • Quote from C6ZZKGT
    hhttps://www.ebay.com/itm/1531851376…e=STRK:MEWAX:IT
    This used Hipo 4 speed flywheel sold August 14, 2019 on Ebay for $699.00.
  • Here is an Ebay auction for a used Hipo 4 speed flywheel by Ebay member "jarsncars" with a Buy-It-Now of $499.00:
    1963-1966 Ford Mustang, Fastback, Coupe, Convertible, GT, Shelby GT350, Cobra, Fairlane, 4 SPEED MANUAL TRANSMISSION FLYWHEEL For 289 HIPO Engine and 10.5"
    Clutch. 160 TOOTH Ring Gear. This is an ORIGINAL FORD PART. Casting Number FoMoCo C3OE-6380-B and dated [5C10]. Removed from a 65 Mustang with 289 HIPO and 4 Speed.
    installation at a minimum. It is 50+ years old and so it will need turned-resurfaced. If you have high expectations for a perfect original OEM flywheel then please pass this one by.
    No Guarantees on this flywheel. No heavy wear. Only surface rust as you can see.
    Has Great Metal. There is some wear on a few of the ring gear teeth. (Pictured).
    The ring can be replaced or turned around. Has a Natural Metal Finish. Overall this is a Great Original 289 HIPO Flywheel. NOT EASY TO FIND ORIGINAL. Please email with questions.
    https://www.ebay.com/itm/1964-1965-…m4383.l4275.c10
  • Do your due diligence on this flywheel. I do not see the ground area on the counterweight where there should be a Brinnel test mark. Therefore I am in doubt as to this being a true Hipo flywheel. A better picture of the counterweight would be in order here.
    This used Hipo 4 speed flywheel sold October 4, 2019 on Ebay for $499.00.
  • Here is an Ebay auction for a used Hipo 4 speed flywheel by Ebay member "jarsncars" with a Buy-It-Now of $459.00:
    Clutch. 160 TOOTH Ring Gear. This is an ORIGINAL FORD PART. Casting Number C3OE-6380-B and dated [4J11]. Removed from a 65 Mustang with 289 HIPO and 4 Speed.
    The Clutch Surface Looks Fine. You should have the surface cleaned It is 50+ years old and it will need turned-resurfaced. This is a used original piece in very good condition.
    The ring can be replaced or turned around. I have a new ring gear that I can sell with this if someone wants it.
    https://www.ebay.com/itm/1965-…1b3c03:g:sNsAAOSwO6hd0XuX
  • Here is an Ebay auction for a used Hipo 4 speed flywheel by Ebay member "automotiveapparel" with a Buy-It-Now of $399.95:
    65 66 FORD MUSTANG SHELBY GT350 ORIG 289 HIPO K CODE 4 SPEED FLYWHEEL
    This listing is for a used OEM Ford 63-66 Ford Mustang 4 speed manual transmission flywheel for 289 engine and 10.5 inch clutch. 160 tooth ring gear with normal wear. Casting number is FOMOCO C3OE-6380-B and dated 5K11. Removed from a 1966 Ford Mustang 4 speed A code. Flywheel was media blasted and re-surfaced by a local machine shop. Check out our other auctions for more cool vintage style items.
    https://www.ebay.com/itm/65-66-FORD…c4AAOSwvzFd8IQE
    Do your due diligence on this flywheel. I do not see the ground area on the counterweight where there should be a Brinnel test mark. Therefore I am in doubt as to this being a true Hipo flywheel. The seller even states in their description that this flywheel came out of an A code Mustang. I posted this as more of a warning to our members here that this is NOT what the seller states in their initial title on Ebay.
  • This used Hipo 4 speed flywheel has been greatly reduced in price to $359.00.
  • This used "Hipo ?" 4 speed flywheel sold January 30, 2020 on Ebay for $359.00.
  • Here is an Ebay auction for a used Hipo 4 speed flywheel by Ebay member "ski7596" with a Buy-It-Now of $600.00 or make offer:
    Ford 289 hipo original flywheel used. Condition is Used.
    New ring gear installed,
    flywheel was resurfaced 500 miles ago, can still see resurfacing marks and no hot spots
    good, flat and solid flywheel
    https://www.ebay.com/itm/Ford-289-h…AoAAOSw8Ehe2-YJ
    Note the huge drill marks in the counterweight where the engine this was attached to was apparently balanced differently than normal. Most likely this flywheel will need to be rebalanced to whatever engine it will be attached to next. Not that is affects the use of this flywheel but it is a later Ford replacement cast September 20, 1971.
  • The listing for this used Hipo 4 speed flywheel was ended by the seller June 29, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
