Starting the refresh of my hipo engine and seems I have a non-hipo fuel pump but can't find out much about the pump that on the engine now. It has a tag of 6838
The content cannot be displayed because you do not have authorisation to view this content. The content cannot be displayed because you do not have authorisation to view this content. The content cannot be displayed because you do not have authorisation to view this content.
The 6838 is an AC replacement pump and not a Carter as original from Ford.
thank you fo reply so you know which Carter this was this a replacement for ?
This is an AC replacement pump for a Carter 3911-S pump which is for standard 65 289 Mustangs, Falcons and Fairlanes. It is much different in appearanvce from the Carter pump.
