Starting the refresh of my hipo engine and seems I have a non-hipo fuel pump but can't find out much about the pump that on the engine now. It has a tag of 6838
The 6838 is an AC replacement pump and not a Carter as original from Ford.
thank you fo reply so you know which Carter this was this a replacement for ?
This is an AC replacement pump for a Carter 3911-S pump which is for standard 65 289 Mustangs, Falcons and Fairlanes. It is much different in appearanvce from the Carter pump.
