• 65 Mustang Fastback Rangoon Red with red pony interior is for sale by Ebay seller "vanguardmotorsales" with a Buy-It-Now of $129,900.00 or make offer:
    Description
    1965 Ford Mustang Fastback 2133
    VIN: 5F09K752133
    Check out this gorgeous 1965 Ford Mustang Fastback! This Mustang has been Rotisserie Restored and it looks amazing inside and out! Take a look at the glossy Red Exterior Paint with White Side Stripes, 14'' Style Steel Wheels, Chrome Bumpers, and the Polished Trim and Exhaust Tips. Inside, this stallion is sporting a Red Pony Interior with Vinyl Upholstery, Front Bucket Seating with Lap Belts, Fold Down Rear Seating, Aftermarket Radio, Center Console Shifter, Red Carpet, Rally Pack of Gauges on the Steering Column and plenty of space in the trunk for your car show essentials.
    Under the hood sits a Ford 289ci V8 Engine with a Cobra Dual Plane Intake Manifold and an Autolite 4100 600 CFM 4 - Barrel Carburetor sitting on top! Power is put to the pavement through a Toploader 4 - Speed Manual Transmission and a Ford 9'' Open Rear End with approximately 3.50:1 Gears! This Mustang is a joy to drive, and it's equipped with 4 - Wheel Power Brakes with Kelsey Hays 4 Piston Front Calipers. The underside of this '65 looks incredible as well and you'll want to put it on display with a set of mirrors! Take a look underneath to see the beautiful condition of the New Looking Fuel Tank, Red Painted Floorboards, New Fuel Lines, New Brake Lines, and Painted Driveshaft, Independent Front Suspension, Leaf Spring Rear Suspension, and the Stainless Dual Exhaust System with correct Hi Po "Long Tube" Manifolds.
    This 1965 Ford Mustang Fastback is an iconic American classic that's sure to compliment any garage! Any collector or enthusiast would love to own this Mustang and it won't last long! Call us today before it's gone!
    Thank you for your interest in this New Arrival. This vehicle is available for purchase. Please allow 4-6 weeks once paid in full to accept delivery. Give Tom a call for more information. 248-974-9513
    Go to http://www.vanguardmotorsales.com to see over 100 HD photos and our in - depth video for this 1965 Ford Mustang Fastback and over 200 other classics!
    Mechanics:
    289 V8
    Engine # C6AE 6015 C
    Casting Date: 6J2 (September/2nd/1966)
    - ARP looking 5/16 Rod Bolts
    - Car Born a 289 Hi - Po
    - Ignition System: Correct Vacuum Pod Delete Distributor That Has Been Converted to Petronix Pointless Ignition (Part # C5OF - 12127
    - Hydraulic Camshaft
    - Correct Hi - Po Thick Balancer
    Stock 1965 Correct Heads with Correct Hi - Po Modification Such as Screw in Rocker Studs
    - Casting Date: 5D28 (April/28th/1965)
    - Comp Cams Roller Tipped Rockers Added
    Single 4 Barrel Carburetor
    Autolite 4100
    - Part #: C5OF J
    - Correct for a 1965 289 Hi - Po Application
    - 600 CFM (Specific to the Hi - Po. Normal 289 Came with 480 CFM)
    - Manual Choke (Hi - Po Specific)
    - Cobra Dual Plane Intake Manifold
    - OEM Ford Fuel Pump with Serviceable Fuel Filter
    Toploader 4 Speed Manual Transmission
    Transmission # HEH - T 016469
    - Car Born a 4 Speed
    - Close Ratio
    - Mustang Correct
    Front Suspension Independent
    Rear Suspension Leaf Spring
    Ford 9"
    3.50
    - Tag: WCZ - M 3.50 5ED 921 (Tag Specifies "High Performance 8 3/4")
    - Casting Date: 5E14 (May/14th/1965)
    - Car Born a 3.50:1
    - Posi
    Front Wheels 14"
    Rear Wheels 14"
    - Style Steel Wheels
    Front Tires 205/70R14
    Rear Tires 205/70R14
    BFGoodrich Red Line Radials
    Front Brakes Power Disc
    Rear Brakes Power Drum
    Dual Exhaust
    - Correct Hi - Po "Long Tube" Manifolds
    - Exhaust From Manifolds to Mufflers Is Stainless
    Body:
    - Chrome in Great Condition
    - Grille looks Good
    - Door Operates Smoothly
    - Fuel Fill looks Good
    Interior:
    - Door Panels are Clean
    - Carpet in Great Condition
    - Front and Rear Seat Belts
    - Center Console
    - Fold Down Back Seat
    - Upholstery is Clean
    - Head Liner is Tight
    - Dash Painted Nicely
    - Rally Pack on Steering Column
    - Chrome in Great Shape
    - Gauge Faces are Clean
    - After Market Radio
    Underneath:
    - Gas Tank looks New
    - Exhaust in Good Shape
    - Painted Floorboards
    - Drive Shaft Painted Nicely
    - Brake Lines are New
    - Fuel Lines are New
    - Wheel Wells are Clean
    Don't miss out! Call Tom 7 days a week! 248-974-9513
    [email protected]
    1965 Ford Mustang Fastback K-Code | eBay
  • This Kar is listed in the registry as originally being a Rangoon Red Kar but with a black standard interior. By the sellers own disclosure, the current engine has a C6AE 6015 C Windsor block which was never used for a Hipo 289. The seller also indicates 5/16" rod bolts which are standard and NOT Hipo 289 parts. There are many other variances from original on this Kar.
    In light of this new information, it would be wise to have a prepurchase inspection done on this Kar prior to any negotiations.
  • This 65 Mustang Fastback Rangoon Red with red pony interior received no bids by December 6, 2022 and therefore did NOT sell.
  • This 65 Mustang Fastback Rangoon Red with red pony interior is back on Ebay again with the same Buy-It-Now of $129,900.00 or make offer:
  • This 65 Mustang Fastback Rangoon Red with red pony interior received no bids by December 13, 2022 and therefore did NOT sell.
  • This 65 Mustang Fastback Rangoon Red with red pony interior received no bids by December 20, 2022 and therefore did NOT sell.
  • This 65 Mustang Fastback Rangoon Red with red pony interior received no bids by December 27, 2022 and therefore did NOT sell.
  • This 65 Mustang Fastback Rangoon Red with red pony interior received no bids by January 3, 2023 and therefore did NOT sell.
  • This 65 Mustang Fastback Rangoon Red with red pony interior received no bids by January 10, 2023 and therefore did NOT sell.
  • This 65 Mustang Fastback Rangoon Red with red pony interior received no bids by January 18, 2023 and therefore did NOT sell.
  • This 65 Mustang Fastback Rangoon Red with red pony interior received no bids by January 25, 2023 and therefore did NOT sell.
  • This 65 Mustang Fastback Rangoon Red with red pony interior received no bids by February 2, 2023 and therefore did NOT sell.
