Have 1964 1/2 289 HiPo engine and transmission. Interested in selling.
Have a 1964 1/2 289 hipo engine and transmission.
Are you looking for an engine & trans or selling .
Selling
Could you post some details . thanks.
C6ZZKGT
October 15, 2022 at 2:57 AM Moved the thread from forum K Mustangs to forum K SpecifiK Parts. -
What is the date? Do
You have a price in mind?
is there a VIN on them? I am looking for 5F07K157666
Do you have the date codes and casting numbers?
Have to make my way to barn with some equipment to hoist engine and trany out. May be a couple of weeks.
Do you have the original drive shaft available for sale? Thx. Mike
Did you ever make it out to the barn?
Any updates?
The content cannot be displayed because you do not have authorisation to view this content. The content cannot be displayed because you do not have authorisation to view this content. The content cannot be displayed because you do not have authorisation to view this content. The content cannot be displayed because you do not have authorisation to view this content. The content cannot be displayed because you do not have authorisation to view this content. The content cannot be displayed because you do not have authorisation to view this content. The content cannot be displayed because you do not have authorisation to view this content. The content cannot be displayed because you do not have authorisation to view this content. The content cannot be displayed because you do not have authorisation to view this content. The content cannot be displayed because you do not have authorisation to view this content. -
How much for the engine?
what is the price for the package
Selling the original drive shaft? How about the nine inch rear? Thx mike
This engine block is a 6 bolt which would have been produced from some time in July 1964 onward. This should help put a time line on this engine. Possibly the last hurrah for the 1964 1/2 Kars as the 1965 Kars started showing up in August 1964.
Can you please clean the tag on the transmission and post the numbers?
Is there a recommended way to clean up tag? Don't want to damage it. Also where would the date code be on the block. Engine and Transmission came out of a 64 1/2 Fastback.
You can clean up the tag with some fine steel wool some times. Yours has enough rust that it will probably take some 600 grit sandpaper and hopefully not coarser than that. Now that you say this engine and transmission came out of a fastback, that makes it a 1965 engine with possibly a 1964 date. Fastbacks were not available until the 1965 model year. The date code is on the underside of the block above the starter. That should be next to the C5AE 6015 E casting number but much smaller.
Ok, Thanks. Got some work to do. Just trying to get a fair value on it.
You only selling engine and trans? I’m interested if your selling the drive shaft and or rear end (not engine and trans). Thx
