Used 6 Bolt Hipo Engine
  • Here is an Ebay auction for a used 6 bolt Hipo engine by Ebay member "fordracer4life" with a Buy-It-Now of $6,500.00 or make offer:
    Selling off some of our collection. Real deal 289 hipo
    Standard bore was disassembled a few years ago. Any questions please ask. No shipping cash only local pick up!
    1965 Mustang 289 Hipo Motor Hipo K Code Fairlane GT 350 High Performance | eBay
  • Here is an Ebay auction for a used 6 bolt Hipo engine by Ebay member "mustangmasters428" with a starting of $7,500.00:
    Here we have a grouping of used Ford 289 High-performance motor pieces which we purchased in one of our recent buyouts. This is a untouched K code standard bore block, Hipo C3AE rods 3/8 bolts with standard pistons, heads, crank, balancer, slinger, intake and chrome valve covers all from a private collectors parts stash. The 271 horsepower 289 Hipo motor was the best Ford had to offer for their earlier model GT Shelby Mustangs and Fairlane's.
    The Shelby GT 350 and all K model Mustangs as well as Hipo Fairlane's all used these 271 HP motors. Amazingly Ford engineers changed almost every piece of this motor to make it stronger with better performance design to add horsepower to their 289 Hipo's
    A rare find we are offering you this stock grouping of un-restored High performance 289 parts for a motor kit. We have lightly cleaned & inspected the pieces to assure the each part is correct and not modified or damaged. Although used it's ready for your use to restore and rebuild to the original spec's & finish. All the Hipo characteristics are present as seen in the photos. We will begin with the dates and then with the design changes. The 6 bolt block has the special solid design main caps and is dated 4K3 (September 3 1964). Factory cast C5AE 6015 E which is correct for a 1965 build as is consistent with the stamped vehicle identification number 5F03K1631634? we located on the center of the block directly above the oil pan.
    We have cleaned and inspected motor block it has no sleeves, grooves, cracks or repairs. Our photo shows a caliper at just under the 4.00 in the cylinder block and that is a standard bore cylinder. Next we have 8 like new correct C3AE rods with heavier 3/8 rod bolts again part of Ford performance upgrade. Each one has the undamaged stock standard bore piston which is consistent with the block we are offering. All pieces have been stored in a climate controlled storage & are left undisturbed for the purpose of this auction. In addition we have a set of used chrome HiPo style valve covers although they are slightly rusted as is shown in pics.
    Next both heads are dated 5 K 14 September 14th 1965 and stamped 19 and 21 consistent with Fords building patterns. You can clearly see the recessed valve saddles and of course factory screw in studs. These 289 castings have a 19 on one head and a 21 on the top corner of the other and a pronounced 4V on both the top and bottom sides. Both of the head footprints are thick (recessed area on bottom of the head to indicate planning or modifications) validating them uncut. The valves and springs are used and should be or could very well need to be replaced with seats when rebuilding occurs. There are no signs of cracks, welds repairs on these are originals which are like the rest of this used collection of pieces unrestored.
    For the top we have the 4L 17 1964 dated cast iron 289 C5AE 9425 M intake correct for 1965 model year car. As to the bottom the crank has the special smooth polish mark part of Fords testing to assure the steel strength. Also offered is the oil slinger another 289 hipo piece & the C5OE-A extra thick harmonic balancer.
    Note: we have some additional Hipo offerings in upcoming auctions such as a restored 289 Hipo carburetor, Ford remanufactured distributor, original exhaust manifolds and a bunch more desirable pieces. As to any other minor pieces not present they are not offered in this auction although we probably have them so ask. Got a need or want to bring that Mustang, Shelby, Fairlane, or any other ford product to life with a 289 to a whole new level of value, performance or strength with a 289 HiPo we have more so ask we come through.
    This is just one of the many Cobra as well as Cobra Jet and other Factory Performance Motor related items we offer each week on EBay! Don't see what you are after we have thousands of parts and pieces usually unavailable from most but not us as we successfully offer the best here weekly on eBay. Just ask us and we will deliver you more hard to find parts and pieces. Be sure to check our other auctions, as we offer a new selection of rare, hard to find desirable parts on eBay or try our full service shop at Mustang Masters.
    This is just a part of our extensive inventory of heads, intake manifolds, exhaust manifolds, carburetors, valve covers, distributors, and other performance-related parts and accessories that we select from for our weekly eBay auctions. Mustang Masters - Your One Stop Parts Shop on eBay!
    1965 Mustang 289 Hipo Motor Hipo 289 K Code Fairlane GT 350 High Performance 289 | eBay
  • The C3AE rods and pistons shown with this engine are for a 390 and NOT for a Hipo 289. I spoke with fast Freddie a couple of days ago when this auction first began, and he is now aware of this issue. He said that he would correct this but as yet, has not done so.
  • Good catch Fred . the dished pistons are a dead giveaway, FYI he has a history of this sort of thing , I am amused with his vending at Ford Carlisle .
    The largest giveaway to me is the extremely wide rods. That stuck out even more than the pistons.
  • This used 6 bolt Hipo engine received no bids by January 16, 2022 and therefore did NOT sell.
    Would August 1965 castings most likely be present in 1966 model year cars? Or is the transition month more so September?
    Thank You,
    Anthony
  • An August 1965 casting would be correct for a 1966 model. The assembly date on this particular one is September 1965. The intake manifold is January 1967. Being as there is no VIN stamp, this could have been a replacement engine for a 1965 model.
  • Thank you! Given the close casting dates of block and heads, standard bore, hipo caps, I was intrigued by this motor, as it “appears” to be original/untouched (as far as internals). I’m picky, so we’ll see if I go for it (relatively local for me to inspect). The fact that you mention it could have been a replacement engine for a 1965 model may be further reinforced by the lack of any evidence of blue paint on the block (black paint only). Unlikely someone stripped all blue paint off throughly while assembled.
    Anthony
    Edited once, last by Yank05 (February 2, 2022 at 11:33 PM).
  • …..oops, I was mistaken, there is blue paint evidence on the block.
    #1 cap has what looks like a small mark or nub, just right of it’s center.
    The listing for this used 6 bolt Hipo engine was ended by the seller February 25, 2022 with the following explanation"This listing was ended by the seller because the item is no longer available".
  • This used 6 bolt Hipo engine by Ebay member "mustangmasters428" is back on Ebay again with the same starting bid of $7,500.00:
  • All of the issues mentioned previously when first listed on Ebay, remain the same.
  • This used 6 bolt Hipo engine received no bids by March 13, 2022 and therefore did NOT sell.
  • This used 6 bolt Hipo engine received no bids by April 24, 2022 and therefore did NOT sell.
  • This used 6 bolt Hipo engine received no bids by June 12, 2022 and therefore did NOT sell.
  • Here is an Ebay auction for a used 6 bolt Hipo engine by Ebay member "fblackgt350h" with a Buy-It-Now of $8,800.00 or make offer:
    289 Ford High Performance engine
    This motor was pulled from a 1966 K Code Mustang. It has around 5000 miles on a complete rebuild by a very reputable machine shop. After motor was pulled most gaskets were replaced. This engine has only had Joe Gibbs Racing oil in it (no oil in it now) What you see in the listing is what you get so pleaase look at pictures carefully.
    C5AE-6015E 6F17 Block with Hipo Main Caps bored 0.30 over.
    Hipo Heads Right Head 21 and Left Head 19
    Rotating assembly balanced to 9000 RPM
    289 Hipo Cam Shaft with Solid Lifters
    Hipo Crank Balancer C8ZE6316A
    New set of Motorcraft BRF32 Spark Plugs
    Aftermarket Cast Iron Water pump (not Hipo)
    Dual Point (HIPO Clone) distributor C5AF 12127 N 5AD
    Timing Chain Cover C4AE-6059 B
    Upgrades include:
    • H-Beam Rods
    • ARP Main Cap Studs
    • Heavy Duty Oil Pump and Drive Rod
    • Roller Rocker arms
    • Cobra Aluminum Intake
    • Cobra Aluminum Valve Covers
    • Cobra Aluminum Oil Pan
    • Heads port matched to the Intake
    This is a great running motor that is near bullit proof with the upgrades.
    This Motor is being sold as is where is with no warranty or return.
    Local Pickup or will work with your Shipper with Offer.
    Free shipping with Buy It Now to lower 48 US States.
    1966 Ford 289 K Code Motor Engine | eBay
  • Here is an Ebay auction for a used 6 bolt Hipo engine by Ebay member "bradsstuffcarsbmxandmore" with a Buy-It-Now of $8,500.00:
    ford 289 hipo engine long block assembly. Block standard bore just magna-fluxed bake blasted heads un-ported un-milled magna- fluxed clean bake blasted standard crank un-turned polished journals pistons rods standard Hi Po balanced and crank slinger not pictured is the flywheel looks to have been balanced at one time valves springs will assemble if necessary block has taper towards the top of the cylinders but no visible ridge this is a Ford Service block date code casting is C8 top of the heads 289 bottom has 302 cast 20 and 21 on the bottom of the heads was running when removed customer went to a larger displacement more HP set-up ... Thank you Brad
    ford 289 hipo engine long block assembly | eBay
