C6ZF F carburetor booster
  • The C6ZF-F assembly (HP289 without TE for automatic transmission) used the "MA" part.
    The "CF" part is listed for a 289 4V without TE for manual transmission. Somebody has made a substitution.
    Dan
    Edited once, last by Dan Case: shorten reply (August 22, 2020 at 4:53 PM).
  • I have a C6ZF F carb and I've read it should have a M or MA primary booster, should I assume that someone swapped mine as its a CF ?
    In answer to your next question, The M and MA boosters are extremely rare and tough to locate as a separate part.
  • Carburetor cores are around but no one I have corresponded with wants to part them out anymore. A genuine core that was "worth" $250± in 2013 now might be "worth" low four figures territory. At $250± a core was worth more broken up into parts but that is no longer true.
    Dan
    Well said, Dan!!
