My 64.5 coupe with palomino interior arm rests have wood instead of vinal pading , is the wood a home made thing by a past owner or a factory piece, they look like original ,thanks in advance , chuck
64.5 arm rest pad
Chuck,
There used to be a reproduction made with a vinyl covering over a wood base.
Brant , thank you for the input removed the wood from the plastic arm rest base , there is a ford part number C4ZB 6524144-A , the wooden part is made from oak , there is no old vinyl covering on it only a old varnish coating, the chrome on the plastic base is worn off as is the top of the wood from daily use , these are from my June 8th build 64.5 K coupe with palomino interior the oak wood tops are a perfect fit unlike a home made part, i plan to send the plastic bases out for rechroming , who would you recomend to send them to, chuck.
Edited by - chucks302 on 12/08/2010 08:44:09
Didn't the special 64 1/2 hardtop made for Henry Ford II have the
same door handles? Just a thought.
Sorry, Chuck. I don't have a recommendation on the plastic plating. Maybe someone else can help you.
You can try this guy out of Madison WI. I have not used him but heard good things about his work.
