So I am rebuilding the one alternator that I think is correct for my 65 K. Two of my screws that hold the casing together broke, so I took the other alternator apart to use the part of the casing under the fan and pulley. I noticed on the one I took it off that the back has Motorcraft on it. Should the one I'm rebuilding have motorcraft on the back also or should it just be stamped? Thanks and let me know if I have only confused you? ![]()
