64.5 Generator Question - need help
  • What are the identifying numbers and location(s) of casting numbers, date codes etc. for a correct generator?
    The HP Mustang Fourth Edition details the casting #s for a generator pully, but fails to provide identifers for the generator.
    I have found several markings on my generator and would like to confirm that it is correct. I have failed to identify any discernable date code.
    This is what I have found on the case - Ford stamp, FBC-10125-A, I also found the following stamped numbers on the back side of the brackets - FAB10139, an upside down 4, an 8, GFA and a B on one side and a 24 on the other side.
    Any help would be greatly appreciated.
  • Thanks Bob
    My car has a Generator Pulley # C3OF-10130-B, which is correct according to the HP Mustang 4th Edition. So would it be correct to state that the Generator must also have C3OF-10130-B on it to be correct?
    As referenced above my Generator has varous numbers on it and the flange/hangers but none are identical to the pulley number.
    Can you tell me exactly where these numbers should be located on the generator?
  • The generator number was specific to the installed pulley. A C3OF-10000-B generator number would have come with the C3OF-10130-B pulley. There were two styles of pulleys used in 1963 and 1964. One was stamped C3OF-10130-B and the other C3OF-B.
    Stamp placement varies, but the attached PDF file will help you place it in the right area. Also, the included graphic is an accuracy redition of the stamping.
    http://www.fordsmallblock.com/Pictures/GeneratorMarkings.pdf
    Edited once, last by bobmannel (February 25, 2010 at 9:06 PM).
