67 Fan Spacer
  • Looking for info on the 67 K-code/GT350 fan spacer, some confusing info out there....
    What is the correct total length including pilot?
    Are there several correct lengths depending on engine options or only one?
    The 65-66 spacer is HiPo specific, is this the same for the 67 spacer(s) or is it also used in non-HiPo applications?
    Thanks!
  • The Ford MPC lists the spacer as 2.44 inches thick which includes the pilot. The only other applications that I could find for it are a 1969 full size Ford 428 police car and a 67 Fairlane with a 289 and hang on A/C. The hang on A/C is not the same as factory installed A/C as the factory installed A/C had fan clutches.
  • Thanks Fred. I've seen the 2.44 inch spacer listed in the MPC, that's where the confusion starts. Bob Mannel's SBF book doesn't list a 2.44 inch spacer for any 67 Mustang application, the closest being 2.74" (with or w/o T/E) or 2.18 (with A/C) and does not show a HiPo specific spacer like 65-66. It does list the 66 Fairlane hang on A/C spacer as 2.42"
