9 inch center section date codes
  • Looking for an answer about some date code questions that i have. my car is dated 10k64 and the center section on the rear axle is dated 4Ell as far as know this is the orginal axle to the car the tag on is dated 4KA and it still has the copper washers under the nuts on it. The other dates on the block are 4G7 and the heads are both dated 4G9 and the intake has date code 4H23. Does anyone else have such a cazy span of dates on their car. If anyone can help with this please let me know.:?::?:
    Edited once, last by 10k64_old (November 22, 2009 at 9:36 PM).
  • Its a dearborn car,or do i hope this normal for cast date codes. I have the understanding that there was a union strike in late 64 would this explane the spread in the date codes?
    Edited once, last by 10k64_old (November 22, 2009 at 10:56 PM).
  • Quote from 10k64
    Union strike? Hadn't heard of one then - was it the assembly, rearend or supplier plant?
  • It was at the ford assembly plant from what i understand. The Auto Workers Union i think is the one that called the strike. You might be able to find something on it on line with one of the newspapers in the area at the time.
  • Found this
    FORD HOPING 50% AT WORK TOMORROW
    Some Recalled to Plants Today
    Chicago Tribune (1963-Current file) - Chicago, Ill.
    Date: Nov 22, 1964
    Abstract (Document Summary)
    Nov 22, 1964 - Ford Motor company expressed hope today that it could return half of its 80000 strike-idled employes to work Monday, but expressed doubt it could get ... Some manufacturing plants continued production, despite assembly line shut downs. So did Ford's steel plants in sub- urban Dearborn. ...
  • Thanks for finding that info, this may explain for some of the gaps in date codes and build dates on these cars. I wonder when it started and how long the stike went on for and how many cars just sat on the line unfinished. The strike must have screwed up a lot of things.
