run numbers please
  • I'd like to ask a favor of the numbers guru's. I'm cleaning the garage, again, and before I dump any valuable parts I'd like to know what they are. Only two items are unknown to me during this round of cleaning.
    1. Flex plate, approx. 13.25 inches dia. 160 teeth with a number like "FOR C4(A)E-63(7)5-B-ASSY". The parenthesis are for the two characters that are not clear. The rest are clear. This part number is on the balance weight of the flex plate.
    2. Metal tag, like found on carbs & intakes. PCS Y
    2006A 703
    Worth anything or do they go into the dumpster with the rest?
    Thank You
    Edited once, last by 66kcar_old (November 2, 2008 at 5:47 PM).
  • C4AE-6375-B is a 1965 289 2V/4V flex-plate
    PCS-Y is a 1966 Mustang 200 6-cylinder C4 automatic tag. The 20006A is actually 200 (6-cylinder) and 06A for January 1966. The 703 is an internal plant code for this transmission (doesn't mean anything outside the plant).
