steering box on 65 k code
  • This box has about 6 inches of play in the steering wheel, when I try and adjust the bolt, I noticed that about 3/4 inch or more was sticking out. Seems to me that only about 1/4 inch should be sticking out...Is it possible that someone screwed the set shaft out too much and had misalignment inside the box causing it not to be able to tighten the bolt down...When the bolt is lost, the shaft will not move, it's way too tight...Also could this be corrected on the car? Thanks Garth
    Edited once, last by SixT5HiPo (December 8, 2010 at 11:12 PM).
  • in my opinion you are just going to have the box rebuilt by a recognized steering authority. At the very least, to properly do the adjustment all the steering linkage will need to be removed from the box.
    Adjusting the box is a multi step affair. Just adjusting the top screw will only make things worse
    http://www.stangerssite.com/adjustment.html
    Z.
    Edited once, last by zrayrichter (December 8, 2010 at 12:07 AM).
  • Quote from garthscars
    Thanks,I figured that it's going to be a relacement of the box..Thanks again Garth
    they can be rebuilt, usually at a cost less than the Flaming River boxes, and at much less cost than the rack & pinion conversions. Once rebuilt, they will last for years, In my opinion a freshly rebuilt Ford steering box compares VERY well with the more expensive rack & pinion systems.
    Z.
  • Don't try to judge the box adjustement by the length of the bolt sticking out as it's not a indicator of the preload on the steering gear. The box should be properly lubriacted and that requires pulling one of the cover bolts and injecting the appropriate amount of grease to fill the gear box. The best way to adjust the box is off the car with the benefit of correct tools and the Ford service manuals. You will also notice a seemingly stiff area in the center of the steering gear where the wheel wants to stay and Ford deliberately designed that into the mechanism to help the car stay centered going down the road.
    Randy at Stanger does a great job and can help out if the box needs to be overhauled.
  • according to posts over at the VMF, Randy is not accepting any more work at the present time. I would check with him to verify this. Do a search over there and you will find several other qualified rebuilders.
    Z.
  • I had my steering box rebuilt earlier this year by Jim @ shelby parts. Can't say enough about the whole process. It took about 2 weeks from start to finish. The box was pretty rough to start with. It is now as close to perfect as I could wish for, both in appearance and operation. I don't remember the exact price but I felt as if it was quite reasonable. I would recommend him highly.
