Help with replacing ignition switch tumbler
  • Hello,
    Can anyone give me some tips on how to change the ignition switch tumbler? Do you just use a paperclip and fish around until it pops out? I hope it is that easy :)
    Thanks in advance.
  • Jim, you need to turn the ignition switch to the accessory position. You can then push your paper clip through the hole depressing the pin that stops the tumbler from turning further counterclockwise. The tumbler can then be turned slightly more counterclockwise and it will slide straight out. Make sure that the replacement tumbler is also turned to the same position for installation. You can practice with your replacement tumbler before trying this. You will be pushing against the spring loaded brass pin with your paper clip.
  • Quote from C6ZZKGT
    Hi Fred,
    Thanks for the advice. The problem I have is that I just bought this car and the previous owner lost the key. Is there a way to remove the tumbler without having the key, or do I need to buy a complete new switch assembly?
    Thank you,
    Jim, either email or PM your phone number and I will call you.
    Hi Fred,
    The owner was able to find the key for me. However, the key was pretty sloppy so I was able to change out the tumbler and it works like a charm now. I appreciate your help.
  • I am happy that worked out well for you, Jim.
