I have a leak at the Nuetral safety switch. Fluid leak around the switch. I have ordered a manual - not here yet!! Is there a seal on the shaft that comes out of the tranny and leaks around this switch or is there a seal below it?
Also the shifter is quite sloppy. When in reverse the reverse lites are not on. you have to be between revers and nuetral for lights to come on. Is there an adjustment on the switch or is the linkage worn out?
The linkages seem quite sloppy? Is there a rebuild kit for this linkage?
so many questions! so much fun!
